cpayne(at)joimail.com Guest
Posted: Wed Jan 23, 2013 4:28 am Post subject: Cold weather starts |
Just a reminder regarding winter operations; cold oil pressure can quickly build high enough to rupture old lines and dirty oil coolers. Never advance the throttle until those temps come up. Hopefully, the PIC will do a visual check before strapping in.
On Yaks/CJ's equipped with remote oil filters, it is the rubber seal in the filter that SHOULD blow out first. This is much better than a line or oil cooler rupture. The best Prevention is to move South failing that, use a heated hanger the night before ops, every part of the airplane gets warmed. If using heat pads, don't forget the oil cooler.
The filter base and elements I supply with remote kits are rated for 200PSI, that is a common value for most equipment on the market. 200PSI can easily be exceeded in a cold oil cooler when the PIC grabs a hand full of throttle.
Stay Safe... I'm going to stay warm.
Craig Payne
Firedog(at)visi.com Guest
Posted: Wed Jan 23, 2013 4:40 am Post subject: Cold weather starts |
Thanks for the reminders...it was -11F yesterday morning...and in FL?
