Posted: Fri Feb 01, 2013 8:50 am Post subject: Removing the baggage door cut-away portion of the fuselage |
On 2/1/2013 9:34 AM, Kelly McMullen wrote:
| Quote: | Check to see if the longeron forward of the baggage door needs
trimming or not. Several of us had to do that cut in situ, without
cutting the skin as the "new" quick build facility didn't cut it to
length.
Yep, that happened to me too. Confusing for a bit...
