Kelly McMullen
Posted: Fri Feb 01, 2013 6:34 am Post subject: Removing the baggage door cut-away portion of the fuselage |
Check to see if the longeron forward of the baggage door needs trimming or not. Several of us had to do that cut in situ, without cutting the skin as the "new" quick build facility didn't cut it to length.
On Fri, Feb 1, 2013 at 7:26 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Yes, that’s exactly what I had in mind, but I wanted to confirm if anyone had done it before.
Carlos
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John MacCallum
Sent: sexta-feira, 1 de Fevereiro de 2013 01:08
Subject: RE: Removing the baggage door cut-away portion of the fuselage skin
Hi Carlos,
I left mine in until I had attached the Tailcone. I thought it better to keep it in place until the riveting of the skin was finished to maintain the shape. It wasn’t a problem cutting it out after I had
Finished the overlaps.
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Carlos Trigo
Sent: Friday, 1 February 2013 3:44 AM
Subject: Removing the baggage door cut-away portion of the fuselage skin
Guys
Question for those who used a QB fuselage:
Did you remove the baggage door cut-away portion of the fuselage skin BEFORE or AFTER attaching the tail cone to the Fwd section of the fuselage?
Carlos 012 34567 890 12345 67
8
A&P/IA, EAA Tech Counselor
KCHD |
