john.heykoop(at)gmail.com Guest
Posted: Thu Feb 21, 2013 3:24 am Post subject: Red Cube transducer k factor |
Hi all
I have just added an Electronics Instruments fuel flow/pressure instrument to my panel, with the "red cube" fuel flow transducer installed in the LAA's preferred location (behind the firewall, in the fuel line from the electrical to the mechanical pump).
I know that that if I use the "auto calibrate mode" when filling the tank the K factor will gradually adjust, so that after a number of refills the instrument should become pretty accurate. However, to give me a head start, can anyone with a similar set up advise to what value I should set the initial K factor so as to get a reasonably accurate reading? My engine is a Rotax 912S.
Many thanks.
G-JHKP mono
