Thumper
Posted: Mon Feb 25, 2013 6:45 am Post subject: Oil Pressure warning? |
Roger and others.
I have been flying this engine, 912ULS, 2000 model year about 1 year, 635 hours total on the engine. One cold day this winter I started getting a high oil pressure alarm intermittently? Oil temps running consistent 160 degrees, 60psi, OAT in the 40's. Warm up is normal, fly for a little while and I will start getting a high pressure warning on my GRT EIS. It will show low 90's for a few seconds then bounce around between 60 and 90 occasionally going over 90 and triggering the alarm. I can find no pattern? I changed the oil to a lighter weight oil (not filter yet) as a test but no difference? What are the possibilities? If it was going low I would be more concerned. It has happened each of the past three flying weekends but only occasionally.
Thanks ahead of time.
Dennis Long
_________________ Dennis Long
Oakland TN
2000 Aeroprakt A20 Vista Cruiser, 2016 A22LS Aeroprakt
Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar.
1200+hours since 1/1/2009 |
Roger Lee
Posted: Mon Feb 25, 2013 7:08 am Post subject: Re: Oil Pressure warning? |
Hi Dennis,
Four common items to look at here and none a big deal.
First the oil pressure wire may be loose on the sender so make sure it is tight. The second item here that cause high pressure swings is a poor ground. This is another very common problem. Check your grounds. The third item is the sender itself is usually the culprit. Go to egauges.com and buy a new one for about $30 if the wire wasn't loose. Third you have a 13 year old engine. You may want to change the oil pressure regulator ball bearing, spring and plug screw to the newer style regulator cone. It's about $80 and takes 5 minutes to change.
It will be one of these.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Mon Feb 25, 2013 7:19 am Post subject: Oil Pressure warning? |
Dennis, I had the same thing in the middle of nowhere in
rural France and my Flydat was much aggravated! It turned
out that the wire to the sender was broken - the no signal
default reading being a high pressure, so odds on it being
a wiring defect.
Regards, David Joyce, G-XSDJ
On Mon, 25 Feb 2013 06:45:32 -0800
"Thumper" <dlong1957(at)yahoo.com> wrote:
Roger and others.
Dennis Long
Dennis Long
Oakland TN
600+hours since 1/1/2009
http://forums.matronics.com/viewtopic.php?p=394984#394984
Un/Subscription,
Forums!
Admin.
joeing701(at)simnet.is Guest
Posted: Mon Feb 25, 2013 7:37 am Post subject: Oil Pressure warning? |
Hello Roger.
What is the part number for the oil pressure sender for the Rotax 912 uls on the egauges.com page?
Appreciate the help.
Johann G.
Iceland.
----- Upprunaleg skilaboð -----
Frá: "Roger Lee" <ssadiver1(at)yahoo.com>
Til: rotaxengines-list(at)matronics.com
Sent: Mánudagur, 25. Febrúar, 2013 15:08:10
Efni: Re: Oil Pressure warning?
Hi Dennis,
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center - Heavy Maint. Rated
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=394986#394986
pestar
Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
Roger Lee
Posted: Tue Feb 26, 2013 7:30 am Post subject: Re: Oil Pressure warning? |
It is the 360-004 for the single pole (single wire) sender
and the 360-430 for the double pole (two wire) sender. Both are 0-150 psi senders.
The fuel sender is the 360-043 0-30 psi.
http://www.egauges.com/vdo_send.asp?Sender=150PSI_10Bar
Tucson, Az.
Cell 520-349-7056 |
rickofudall
Posted: Tue Feb 26, 2013 7:31 am Post subject: Oil Pressure warning? |
Don't rule out the EIS. GRT make a great product, but my EIS gets grumpy in cold weather and the altimeter resets to -2,850 ft. I'd have thought subterranean flying would be darker, but I can see no difference except that the altimeter reading gets smaller as I ascend.
Rick Girard
On Mon, Feb 25, 2013 at 8:45 AM, Thumper <dlong1957(at)yahoo.com (dlong1957(at)yahoo.com)> wrote:
| Quote: | --> RotaxEngines-List message posted by: "Thumper" <dlong1957(at)yahoo.com (dlong1957(at)yahoo.com)>
Roger and others.
Dennis Long
Dennis Long
Oakland TN
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
