spcialeffects
Posted: Fri Feb 22, 2013 11:00 am Post subject: Classic aileron |
Could someone just confirm for me if what I am thinking is correct please. The XS ailerons come in two sections but the older classic ailerons came as one ( once layed up will be 1.4 meters long ). Is this correct? Many thanks
alanb(at)dpy01.co.uk Guest
Posted: Fri Feb 22, 2013 11:46 am Post subject: Classic aileron |
My Classic certainly came as described.
Alan
#0303
Sent from my iPad
On 22 Feb 2013, at 19:00, "spcialeffects" <spcialeffects(at)aol.com> wrote:
http://forums.matronics.com/viewtopic.php?p=394818#394818
spcialeffects
Posted: Fri Feb 22, 2013 11:57 am Post subject: Re: Classic aileron |
Hi Alan can you please confirm, it came as 1 or 2 pieces?
houlihan(at)blueyonder.co Guest
Posted: Fri Feb 22, 2013 12:22 pm Post subject: Classic aileron |
I can confirm that the classic aileron is made using one blue foam core, \\\\\\\\\\from memory some extra work is / was required on the inboard closeout.
On 22 February 2013 19:57, spcialeffects <spcialeffects(at)aol.com (spcialeffects(at)aol.com)> wrote:
[quote] --> Europa-List message posted by: "spcialeffects" <spcialeffects(at)aol.com (spcialeffects(at)aol.com)>
http://forums.matronics.com/viewtopic.php?p=394824#394824
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
Posted: Fri Feb 22, 2013 12:32 pm Post subject: Classic aileron |
I piece per aileron.
Alan
Sent from my iPad
On 22 Feb 2013, at 20:21, houlihan <houlihan(at)blueyonder.co.uk (houlihan(at)blueyonder.co.uk)> wrote:
[quote]I can confirm that the classic aileron is made using one blue foam core, \\\\\\\\\\from memory some extra work is / was required on the inboard closeout.
spcialeffects
Posted: Fri Feb 22, 2013 12:33 pm Post subject: Re: Classic aileron |
Thanks for the confirmation Tim
spcialeffects
Posted: Fri Feb 22, 2013 2:14 pm Post subject: Re: Classic aileron |
Thanks very much guys
nigel_graham(at)m-tecque. Guest
Posted: Sat Feb 23, 2013 3:32 am Post subject: Classic aileron |
Yes I can confirm that.
The classic used a short-and-fat one-piece aileron, whereas the XS
uses a long and thin component construed out of two foam cores that need
bonding prior to layup.
On 22/02/2013 19:00, spcialeffects wrote:
