kjburns(at)btinternet.com Guest
Posted: Wed Oct 30, 2013 6:51 pm Post subject: A Europa re-born G-EINI |
At 3 pm today G-EINI, found her place in the autumnal sky over Husbands Bosworth, she is only 2 LBs heavier than when first built despite the additional Tri-Gear , (I have also dropped 2 and 3/4 stone while removing all the old paint and excess filler).
We chose grass option (27)due to the cross wind, and at 5lb less than gross lifted off without complaint, she flies delightfully, fully co-ordinated, with hands free flight showing a beautifully balanced aircraft...no trim tabs needed here (I have a bucket full of the ones we removed when setting up the aircraft).
The engine is still tight with only 2 hours total running time on it so we were gentle with the test schedule preferring to cruise climb to 3500 ft and check stall characteristics, stall buffet is gentle but noticeable , and flaps are free of any adverse roll effects, 43 knots clean and the right wing dropped first , but with a nice rumble first.
Ventilation could have been better, new door seals and closure panels leave little exit air, and the carpets were not fully dry..I was a bit warm too ! so misting on my screens had to be kept clear.
Rain was approaching from the west as an hour in the air approached so we chose the wide and long option of the grass 27 (winch cables gone for the approaching weather) , and made a high brisk approach of 75 Knots over the hedge to put us nicely down floating over the cross track next to the launch point bus.
Back to the Hanger, cowls off, a good once over and tweak a couple of avionics issues ..fish and chip supper and check the weather for tomorrow's flight testing , cant believe were flying !
Many thanks to Richard Kilham, Mentor and inspector (and test pilot) from EES Aviation, for his valuable contribution and enthusiasm for this project.
To all at the Sywell show, I said two weeks to finish...I was right ..two weeks for the jobs on my list...I managed to find another 6 weeks of jobs to do as well !
Kevin.
rlborger(at)mac.com Guest
Posted: Wed Oct 30, 2013 7:07 pm Post subject: A Europa re-born G-EINI |
Kevin,
Congratulations on the return to the air! Sounds like you have a fine bird there. Enjoy!!
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop.Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Oct 30, 2013, at 9:50 PM, K BURNS <kjburns(at)btinternet.com (kjburns(at)btinternet.com)> wrote:
Kevin.
