nimbusaviation(at)YAHOO.C Guest
Posted: Sun Mar 17, 2013 12:59 pm Post subject: SV: SV: fuel flow and return line status |
Clive, group,
My recollection is the FS02 sits with the recess upstream, in other words on the carb side not the tank side - visible when you poke it into the hose - it's firmly lodged in there, and removal needs cutting some hose; it will not migrate?
I am nervous about any solution which involves just poking the aperture clear of blockage. I am also concerned about a tiny restrictor fitting pushed into a hose and maybe 'forgotten', out of the interval inspection list too.
This tiny hole is vulnerable to collecting debris, so if found blocked the fix should I think involve root-cause discovery - in our case it was probably perishing hose beyond swap out interval -there's plenty of it in the Europa as we know.
Prevention is perhaps the next step? Again, methinks an in-line filter upstream, but many extra variables there plus the whole issue of 'Approval', so we've not considered that further.
Our Rotax agent pointed out that the carb has internally a similar sized aperture in the fuel path.
Glenn Rainey
G-OJHL
Cumbernauld,Scotland
