		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Thu Mar 21, 2013 6:39 am    Post subject: Seat backs |
				OK, Maybe I'm missing something here but I have one of "those" questions. Before you ask, I did a search but turned up nothing useful.
 Looking at the XL cockpit, I'm wondering what others have done to deal with the wide gap behind the seat back?  Do you build some kind of stiffening into the seat cushion or?
 I was thinking of spanning the gap with some 0.016 or 0.025 held in position by screws and nutplates.  Comments?
 Tim
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		n1269k
				 Posted: Thu Mar 21, 2013 6:49 am    Post subject: Re: Seat backs |
				Hi Tim
 My seat back cushion is made of, I think, 3/8" plywood. Works great.
 Terry
		psm(at)att.net Guest
				 Posted: Thu Mar 21, 2013 7:12 am    Post subject: Seat backs |
				Hi Tim,
 I made seat backs from plywood - 1/4 inch Nordic Birch, I think. Each
 seat back is held in place with 4 screws and nut plates.
 I don't think you want to seal up the big hole between the baggage cross
 piece and the one on the fuselage bottom.  Access is necessary to get to
 the aileron cables and other stuff that winds up back there like radio
 antennas.  I also have a bunch of electric barrier blocks to connect all
 the stuff in the rear to the instrument panel.  This includes stuff like
 trim switches on the stick, radio transmit key, lights, and I don't know
 what else.  I used barrier blocks from Radio Shack mounted on bent
 aluminum pieces.
 Paul
 Camas, WA
 On 3/21/2013 7:39 AM, Tim Juhl wrote:
  Tim
  ______________
  CFII
  Champ L16A flying
  Wing modifications done - back working on the fuselage
  http://forums.matronics.com/viewtopic.php?p=396740#396740
		bryanmmartin
				 Posted: Fri Mar 22, 2013 1:16 am    Post subject: Seat backs |
				I used 1/8" birch ply-wood; The stuff used under vinyl flooring. I riveted a strip of aluminum angle horizontally a few inches below the top and bent that around the top edge of the baggage shelf support. The seat back cushion is velcroed to the wood. There are no fasteners holding the wood in place, just gravity. I can just lift up on the seat back to disengage the aluminum angle from the shelf support and fold it forward to access the area behind the seat.
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus re-drive.
 On Mar 21, 2013, at 10:39 AM, "Tim Juhl" <timjuhl(at)frontier.com> wrote:
  Tim
  _________________ --
Bryan Martin
do not archive. |
		Ron Lendon
  Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
				 Posted: Fri Mar 22, 2013 8:22 am    Post subject: Re: Seat backs |
				1/4" Luan in the seat back cushion, just fits in the seat cover and is zippered into the cushion.  Industrial Velcro holds things in place.  Followed http://www.seatfoam.com/index.html guidance in carving the foams up.  Pretty sure I purchased the foam from them also.  Not cheap but very comfortable on long flights.
  _________________ Ron Lendon
CH 601 XLB
N601LT  - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
		paulrod36(at)msn.com Guest
				 Posted: Fri Mar 22, 2013 2:06 pm    Post subject: Seat backs |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  I think you'll find the aluminum to be a bit too flexible.   I  used some 3/16" underlayment plywood from Lowe's, (nice looking grain) 22" wide,  and about 19" long, and fabricated tops to go over the seatback top. Easily  removable, and nice and strong.
  Paul Rodriguez
  [quote]   ---
		larrycmcfarland(at)gmail. Guest
				 Posted: Fri Mar 22, 2013 7:21 pm    Post subject: Seat backs |
				Hi Tim,
 I’d suggest you look at the seat page I put together for the 601
 http://www.macsmachine.com/html/seatupholstery.htm
 Hope it is helpful,
 Larry McFarland
 From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of paulrod36(at)msn.com
 Sent: Friday, March 22, 2013 5:06 PM
 Subject: Re: Seat backs
 Paul Rodriguez
		Tim Juhl
				 Posted: Tue Mar 26, 2013 3:48 pm    Post subject: Re: Seat backs |
				All very useful information, thanks!
 I should have asked this question at the start but here goes.  I haven't crawled into my fuselage yet (think I'll wait until it is on the gear) but was curious about the optimum height of the seat back. I'm 6'1" tall, so can anyone suggest how much, if any, I should extend the seat back above the top support?  With the laid-back orientation of the Zodiac seat I would think that some head support would be in order.
 Thanks!
 Tim
CFII
Champ L16A flying
				 Posted: Tue Mar 26, 2013 4:16 pm    Post subject: Seat backs |
				Hi Tim,
 I don't have any head support in mine and I am comfortable in the seat.
 The important issue, from my perspective, is the constitution of the
 cushion you provide for the seat.  This trumps the seat back which
 mostly serves to cover the big hole below the baggage compartment cross
 piece.
 I got a hold of three different kinds of foam which I used in my seat
 cushions.  There are two different memory foam (pink and blue) and heavy
 grade polyurethane foam on top - the kind recommended for dinner chair
 cushions.  These are covered with Duck cloth.  I wanted to try leather
 but I decided the cloth was more comfortable.
 Have fun,
 Paul
 Camas, WA
 On 3/26/2013 4:48 PM, Tim Juhl wrote:
  Thanks!
  Tim
  ______________
  CFII
  Champ L16A flying
  http://forums.matronics.com/viewtopic.php?p=397144#397144
		bryanmmartin
				 Posted: Wed Mar 27, 2013 1:33 am    Post subject: Seat backs |
				I built a mock-up of the seat from wood so I could test the seat design. I used the mock-up to build up the seat foam pieces and glue them together before I took them in to the upholsterer. It was easier than trying to do it in the cockpit itself.
 Bryan Martin
 N61BM, CH 601 XL,
 On Mar 26, 2013, at 7:48 PM, Tim Juhl <timjuhl(at)frontier.com> wrote:
  	  | Quote: | 	 		   I should have asked this question at the start but here goes.  I haven't crawled into my fuselage yet (think I'll wait until it is on the gear) but was curious about the optimum height of the seat back. I'm 6'1" tall, so can anyone suggest how much, if any, I should extend the seat back above the top support?  With the laid-back orientation of the Zodiac seat I would think that some head support would be in order.
  Thanks!
Bryan Martin
do not archive. |
