n100rh(at)sbcglobal.net Guest
Posted: Thu Jan 12, 2006 3:25 pm Post subject: gear lock down |
Dan,
I couldn't stand the risk of that lock being moved and the gear coming
up. So, for on the ground operations I put a 1/4" dia x 2 1/4" pip pin
in front of the gear lever, across the tunnel/slot, which prevents the
gear being moved, period, no oops, nada. Old habits from the Navy and
jets... die hard.
Ralph
Dan Bish
Posted: Fri Jan 13, 2006 1:21 pm Post subject: gear lock down |
If you have a photo I'd sure appreciate it. I'm having trouble picturing
what exactly you're slipping the pin into.
Dan
[quote]--
_________________ Kit A144 - N914RB
Mono, 914F
About 40% done, CM finished, most controls, tower, tailplanes, etc. Working on wing incidence and landing gear. |
