occom(at)ns.sympatico.ca Guest
Posted: Sat Jun 10, 2006 12:37 pm Post subject: fabric finishing/ spar renewal. |
Thanks Fred, and the others who emailed off list. The only one I have not heard about is Loehle. Looks like I'll use the Stits when I get to that stage.
Disassembly has started, I used a soldering gun/hot knife to remove all the epoxy from one rib. I may cut the old spar off in sections. This is going to take a while. It looks like the original spar ends about midway between ribs 7 and 8. It appears to have an I-beam insert extending beyond the original one.
I'll take some pictures.
