Oil Temps
Strasnuts
PostPosted: Mon Mar 25, 2013 8:46 pm    Post subject: Oil Temps Reply with quote
I believe nonstop aviation makes the oil cooler butterfly valves. I have one and it works great. Very easy to adjust by using a control knob with detents. Vans sells them. Glad to hear you fixed the issue. My #5 is the hottest.
On Mar 25, 2013, at 22:23, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
[quote]This winter I figured out a way to fix 2 Heat related issues that have been with me since day one. 1. My # 6 cylinder ran 20-30 degrees hotter than any of the other. On hot (AZ) summer day's, I had to pay close attention to keep the Cyl temp under 420-430 deg on climbs. 2. my oil temps would also exceed 220 on long climbs to altitude and during the middle of summer if the OAT didn't get below 70F degs, the Oil Temp would stay above 200. Even on 'cooler days' it would rarely go below 196. So I fabricated a fiberglass intake that replaces to the slot cover in the lower cowl in front of the nose gear. and plumbed it to the Oil Cooler (in the same std location). I plugged the old 4" opening behind the # 6 cyl. The results after a couple of flights look encouraging. The #6 cyl, is now in line with the other cyls. (12 deg spread across all cyls). Last weekon a trip from DVT to SLC, in cruise the oil temp never got above 165 degrees. the OAT (at) 10-11k was 0 to -4 C.
So I'm a bit worried that the oil temps are now too cool. I've been of the opinion that the ideal oil temp is aprox 180 deg in order to cook off any moisture in the oil. So I'm wondering if I need to put a valve in-line somewhere to help regulate the oil temps. Any feedback is appreciated.
Deems
://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
robin(at)PaintTheWeb.com
PostPosted: Mon Mar 25, 2013 9:09 pm    Post subject: Oil Temps Reply with quote
Great news Deems. Another option for oil cooler control is to place a hinged flap on the back side of the oil cooler. I have one with my new cowl set up that closes off up to 60% of the oil cooler and has allowed me to gain much control. Only 60% due to motor mount conflict (yours may be different) but it seems to be all the control I need. I have also had the butterfly version on other aircraft and generally prefer that solution mostly due to no additional room is required FWF. But this hinged flap was a simple solution that worked with my current control cable set up and functions well. If I lived in UT I would opt for 100% closure (and a good realtor) Smile
Robin
Sent from the new iPad
On Mar 25, 2013, at 9:50 PM, "Seano" <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote] I believe nonstop aviation makes the oil cooler butterfly valves. I have one and it works great. Very easy to adjust by using a control knob with detents. Vans sells them. Glad to hear you fixed the issue. My #5 is the hottest.
Deems
cs.com
p://www.matronics.com/Navigator?RV10-List
ics.com
.matronics.com/contribution
Kelly McMullen
PostPosted: Mon Mar 25, 2013 9:18 pm    Post subject: Oil Temps Reply with quote
Sounds good Deems. I think you are fine on oil temp. Remember that the
temp sensor is at the return line from the oil cooler, and temps in
the sump can run as much as 50 degrees hotter.
Deems
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Greg McFarlane
PostPosted: Tue Mar 26, 2013 2:47 am    Post subject: Re: Oil Temps Reply with quote
Sounds good Deems, does your fiberglass vent in front of the nose gear leg hang down into the airstream and did you use the four inch scat to the oil cooler? Also have you figured out a quick on/off for the scat to cooler when you remove the cowls?
Lew Gallagher
PostPosted: Tue Mar 26, 2013 3:31 am    Post subject: Oil Temps Reply with quote
Uh Oh, Deems poked his head out and saw an airplane – must be Spring for sure!
Sounds like an excellent solution. Still James cowl, right? I’d love to see some pictures of your scoop.
We’re scheduled to loose the tower here at Donaldson in Greenville, SC – we’ll see how it goes.
Later, – Lew “relieved to be back to plain plane issues� Gallagher
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
Deems Davis
PostPosted: Tue Mar 26, 2013 8:20 am    Post subject: Oil Temps Reply with quote
Greg,
yes it does hang down into the air stream  I used a 3.12" mailing tube as the  mandrel to form the inlet tube and then faired it into the attach/cover plate with micro/body filler , put a 3/4+ radius around the inlet and then covered the whole thing with another couple of layers of fiberglass. I used 3 1/4 " scat tube, and fabricated a fiberglass reducer elbow that connects the scat to the oil cooler box. I may have some pics. I use a stainless steel expandable clamp to attach/remove the scat tube when taking the cowl off.
Deems
On Tue, Mar 26, 2013 at 3:47 AM, Greg McFarlane <grbcmcfarlane(at)gmail.com (grbcmcfarlane(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: "Greg McFarlane" <grbcmcfarlane(at)gmail.com (grbcmcfarlane(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=397071#397071
le, List Admin.
bruce1hwjohnson(at)yahoo.
PostPosted: Tue Mar 26, 2013 9:10 am    Post subject: Oil Temps Reply with quote
Hey Deems, you never got back with me on the $5 bet I sent you on who's 10 is faster. Whats up?
Sent: Tuesday, March 26, 2013 9:19 AM
Subject: Re: Re: Oil Temps
Greg,
Deems
le, List Admin.
