mhcrowder
Posted: Mon Apr 01, 2013 11:14 am Post subject: Distributor Shaft Seals |
Looks like I need to replace the seal on my passenger side distributor shaft. The part call-out from the Parts Book is "PG10622N Seal Distributor Shaft 15x24x7". Seeing that SnF starts next week, I'm guessing that the Jabiru crew will be plenty busy with that for awhile. Does anyone have an alternate website for ordering the seals? Any specific part number?
Also, any tips and/or hints for the replacement will be greatly appreciated.
Michael
Sonex N293SX
_________________ Michael Crowder
Jabiru 3300A w/ Hyd Lifters
EFI |
Lynn Matteson
Posted: Mon Apr 01, 2013 12:10 pm Post subject: Distributor Shaft Seals |
Why not try your local ball bearing and seal dealer? Ask for a seal
with the dimensions: 15 mm ID, 24 mm OD, and a width of 7 mm.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1419 hrs... (since 3-27-2006)
On Apr 1, 2013, at 3:14 PM, sonex293 wrote:
<sonex293(at)gmail.com>
appreciated.
Michael
Sonex N293SX
Michael Crowder
EFI
Sonex N293SX
http://forums.matronics.com/viewtopic.php?p=397551#397551
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
pete(at)usjabiru.com Guest
Posted: Mon Apr 01, 2013 2:24 pm Post subject: Distributor Shaft Seals |
Our parts depart will be open during SNF week.
Pete
mhcrowder
Posted: Mon Apr 01, 2013 2:44 pm Post subject: Distributor Shaft Seals |
Ok, I found the following website but it has 4 possible seals...
http://tinyurl.com/oilseal
Which is the correct one?
1. 15X24X7VDC-METRIC OIL SEAL-15MM X 24MM X 7MM ($9.80/each)
2. 15X24X7TC-METRIC OIL SEAL-15MM X 24MM X 7MM ($1.54/each)
3. 15X24X7SC-METRIC OIL SEAL-15MM X 24MM X 7MM ($2.16/each)
4. 15X24X7SC-T-METRIC OIL SEAL-15MM X 24MM X 7MM ($2.16/each)
I'm guessing it would be #3, but that is purely a guess.
Michael
On Mon, Apr 1, 2013 at 3:43 PM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
| Quote: | --> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
with the dimensions: �15 mm ID, 24 mm OD, and a width of 7 mm.
Lynn Matteson
Jabiru 2200, #2062
EFI
mhcrowder
Thanks Pete. Just shot them an email....
Michael
On Mon, Apr 1, 2013 at 6:17 PM, Pete Krotje <pete(at)usjabiru.com (pete(at)usjabiru.com)> wrote:
[quote]--> JabiruEngine-List message posted by: "Pete Krotje" <pete(at)usjabiru.com (pete(at)usjabiru.com)>
Pete[b]
EFI |
mhcrowder
Posted: Thu Apr 04, 2013 11:22 am Post subject: Re: Distributor Shaft Seals |
Wow.... Jabiru really likes the seals..... $24 each before shipping.
EFI |
Posted: Thu Apr 04, 2013 12:29 pm Post subject: Distributor Shaft Seals |
Yes, the parts are getting more expensive. Take the normal cost of that
seal then add 10% for the cost of currency exchange, add 20% for shipping
and customs clearance (our average on all parts is about 21.7%) and add some
margin for Jabiru USA and yes - you get $24.00 each.
Pete
