Sean Blair
Joined: 09 Jan 2006 Posts: 39 Location: Colorado Springs
Posted: Sun Jun 11, 2006 2:54 pm Post subject: Double flush or not |
Double flush or not? When I look at my plans for Section 28-12, the rivet callout, there appears to be a discrepancy. I see in the websites of other’s that they are installing double flush rivets on the last seven outboard rivets attaching the forward center section bulkhead assembly and skins. My plans do not reference this and it may cause a clearance issue later with the landing gear and the shop heads of those rivets. What’s even stranger is the plans seem to both be the same revision “0” and I don’t see a bulletin from Van’s. I’m not totally sure this is a problem yet. Yes, I installed these rivets already.
Referencing Tim O’s site:
http://www.myrv10.com/Plans/RV10_Plans_sec28-pg13.html
(mine doesn’t have the double flush callout)
Is everyone using double flush here?
Sean Blair
#40225
_________________ Sean S. Blair
#40225
N967SB (reserved) |
bob.kaufmann(at)cox.net Guest
Posted: Sun Jun 11, 2006 3:36 pm Post subject: Double flush or not |
I did a double flush here, the clearance was an issue.
Bob K
Building engine
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Blair
Sent: Sunday, June 11, 2006 2:53 PM
Subject: Double flush or not
Sean Blair
#40225
Deems Davis
Posted: Sun Jun 11, 2006 3:58 pm Post subject: Double flush or not |
Yep, double flush, or the Landing Gear mount won't fit. (Ask me how I know)
Deems Davis # 406
Fuse
http://deemsrv10.com/
Sean Blair wrote:
| Quote: | Double flush or not? When I look at my plans for Section 28-12, the
Sean Blair
#40225
Rick S.
Posted: Sun Jun 11, 2006 7:16 pm Post subject: Double flush or not |
Yup discrepancy...double flush it...
Rick S.
40185
Fuse/Finish
_________________ Rick S.
RV-10
40185 |
