rv8iator(at)gmail.com Guest
Posted: Sat Apr 06, 2013 11:30 am Post subject: transmitter power attenuator |
I saw a recent post from Bob discussing using a 100 ft piece of coax connected to the comm antenna serving as an attenuator allowing for bench testing of a comm radio (xmit) without connecting to a conventional antenna.
My question is, will this also work for a transponder?
I am testing a new panel but do not have any antennas mounted to the the airframe and need to verify proper operation of each radio. I do have a dipole antenna (tuned for 118-136 Mhz) mounted on the roof of the shop I use for testing operation of the comms. But I haven't found any procedure for testing the transponder and ADS-B UAT which are 1090 Mhz and 978 Mhz without using their respective antennas.
Chris Stone
RV-8
GNS 430, AFS EFIS, Navworx ADS-B, Val comm, PMA 4000
Posted: Sat Apr 06, 2013 2:18 pm Post subject: transmitter power attenuator |
At 02:30 PM 4/6/2013, you wrote:
| Quote: | I saw a recent post from Bob discussing using a
My question is, will this also work for a transponder? Â
Even better yet. Attenuation at 1050 is a LOT higher
than at 126.
| Quote: | I am testing a new panel but do not have any
verify proper operation of each radio. Â I do
testing operation of the comms. Â But I haven't
Hmmmm . . . that's a bigger problem and I'm
not conversant with those systems. Waaayyy back
when I used to have one of those AirSport eavesdroppers to
check a transponder for gross functionality. You could
lay a 110v drill motor on the ground under the xponder
antenna and tie it into the ON position with a rubber
band.
Noise from the motor would tickle the transponder
into fits of apoplexy . . . it would begin to
squirt out mode c replies which could be read
on the AirSport faceplate. Kinda handy sometimes.
But all that newfangled stuff . . . I don't know.
Posted: Sat Apr 06, 2013 5:36 pm Post subject: transmitter power attenuator |
Here's the AirSport Corporation electro-whizzy. Looks
like they are still in business. Haven't had any direct
contact with them in 10-15 years.
http://tinyurl.com/ca8mgkv
Posted: Sat Apr 06, 2013 5:49 pm Post subject: transmitter power attenuator |
BobsV35B(at)aol.com Guest
Posted: Sat Apr 06, 2013 6:08 pm Post subject: transmitter power attenuator |
Good Evening Bob,
I bought one a year or so ago. The main thing I use it for is to be sure what my transponder is sending to the FEDs.. I set it on top of my glareshield and I can see what my stuff is telling the FED!
I like it, but would prefer that it be smaller.
Happy Skies,
Old Bob
In a message dated 4/6/2013 8:50:35 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Sun Apr 07, 2013 6:01 am Post subject: transmitter power attenuator |
| Quote: | From: Christopher Cee Stone <rv8iator(at)gmail.com>
Zaon makes two portable collision avoidance systems, the MRX and XRX.
Likely a local pilot will have one of these you could borrow.
Both will display the transponder code and altitude of what it is
transmitted by the local transponder.
Jeff Page
Dream Aircraft Tundra #10
Posted: Sun Apr 07, 2013 6:44 am Post subject: transmitter power attenuator |
At 09:07 PM 4/6/2013, you wrote:
| Quote: | Good Evening Bob,
I like it, but would prefer that it be smaller. |
If the original designer/manufacturer were still
in business, it might have become smaller by now.
I met Daryl and Pat Phillips in OSH about 1990.
Their mom-n-pop business in Salisaw OK was rather
young then. Daryl was the one and only designer and
software writer. He was using Motorola 6800 series
chips as I recall.
The thing uses a rather large battery.
They sold the business to one of their employees
some years ago. To be sure, more modern processors,
components and materials offer opportunity for
shrinking the size down . . . and even making it run
on three or four AA cells. But I don't think
that's going to happen now.
It IS a pretty slick gizmo.
Bob . . . [quote][b]
Posted: Sun Apr 07, 2013 12:28 pm Post subject: transmitter power attenuator |
Bob, Bob et al,Thanks for the info... My primary concern at this time was to insure I wouldn't damage the xponder upon power up if I inadvertently hit the ident button. As far as test equipment goes the shop should be able to verify operation when I get my pitot/static check. The ADS-B checkout is another matter. The Navworx box does have a self test that validates it is receiving the serial data from the alt. encoder and displays the output on the EFIS screen. Still need to learn the procedure for validating communication with the ground station. The technology is still in it's infancy as the FEDs are in process of adding ground stations to re-transmit traffic and weather data. I'm still learning.. but that's the idea isn't it!
Chris
On Sun, Apr 7, 2013 at 6:49 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
chips as I recall.
Bob . . . | Quote: |
tp://forums.matronics.com
Posted: Sun Apr 07, 2013 12:57 pm Post subject: transmitter power attenuator |
Jeff,
Thanks... Great tip! I think my local FBO has them in a couple of rentals.
chris
On Sun, Apr 7, 2013 at 7:00 AM, Jeff Page <jpx(at)qenesis.com (jpx(at)qenesis.com)> wrote:
[quote] --> AeroElectric-List message posted by: Jeff Page <jpx(at)qenesis.com (jpx(at)qenesis.com)>
| Quote: | From: Christopher Cee Stone <rv8iator(at)gmail.com (rv8iator(at)gmail.com)>
Zaon makes two portable collision avoidance systems, the MRX and XRX. Likely a local pilot will have one of these you could borrow.
Both will display the transponder code and altitude of what it is transmitted by the local transponder.
Jeff Page
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
-Matt Dralle, List Admin.
