Pulsar-List Digest: 3 Msgs - 04/07/13
Bob H
PostPosted: Mon Apr 08, 2013 6:35 am    Post subject: Pulsar-List Digest: 3 Msgs - 04/07/13 Reply with quote
Dennis;
4340 has more carbon (30%) than 4130 so weldment has higher chance of
cracking after cooling. You want to keep carbon content in steel for welding
below .30%, hence 4130 is better choice. 4340 is alloyed to provide more
through hardenability in thick sections and does not provide much advantage
in a 3/4" dia rod over 4130. You don't want to weld heat treated 4340 parts;
can get away with welding 4340 if it is just in normalized condition.
The design I built just used normalized 4130 welded to itself and no welding
on the swivel shaft to make problems.
Bob H
From: Pulsar-List Digest Server <pulsar-list(at)matronics.com>
Reply-To: <pulsar-list(at)matronics.com>
Date: Sun, 7 Apr 2013 23:58:20 -0700
To: Pulsar-List Digest List <pulsar-list-digest(at)matronics.com>
Subject: Pulsar-List Digest: 3 Msgs - 04/07/13
Today's complete Pulsar-List Digest can also be found in either of the
of the Pulsar-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2
013-04-07&Archive=Pulsar
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter
Pulsar-List Digest Archive
Total Messages Posted Sun 04/07/13: 3
Today's Message Index:
1. 04:06 PM - Nose Gear (Dennis Adams)
2. 04:20 PM - Re: Nose Gear (GREGSMI(at)aol.com)
3. 05:05 PM - Nose gear (Dennis Adams)
________________________________ Message 1
_____________________________________
Time: 04:06:44 PM PST US
Subject: Nose Gear
Sent from an IPad
After checking my nose gear, I decided to cut the collar off and
machine a 4130 by 3/4 steel rod to fit the nose gear down leg at the
proper angle. Then machined the rod down to 5/8 to go through the
yoke and threaded the end past the yoke, then welded the rod in place.
I am hoping this will work well. Without the collar the entire pin
and weld is visible. I also found that the cast aluminum yoke had
stretched and was developing excessive play. Fortunately I have a
spare aluminum yoke.
Dennis.
AD pulsar XP
N375CM
________________________________ Message 2
Time: 04:20:38 PM PST US
Subject: Re: Nose Gear
Dennis, we found that the 4130 had a hardness of 90ksi while the bolt used
in the original was rated at 130ksi. Keep a lose eye on it and please keep
us informed of how things are going.
Greg
In a message dated 4/7/2013 6:07:11 P.M. Central Daylight Time,
ghf4986(at)gmail.com writes:
Sent from an IPad
Dennis.
AD pulsar XP
N375CM
________________________________ Message 3
Time: 05:05:38 PM PST US
Subject: Nose gear
In my previous note I used the wrong steel specification, I meant to
type 4340 steel. This is what I used for my nose pin.
Dennis
Sent from an IPad
PostPosted: Mon Apr 08, 2013 11:45 am    Post subject: Pulsar-List Digest: 3 Msgs - 04/07/13 Reply with quote
Bob,
As always, thanks for the information, your the expert. I will keep a
really close eye on the weld.
Dennis
Sent from an IPad
On Apr 8, 2013, at 8:37 AM, Bob Hartunian <bobh5(at)earthlink.net> wrote:
Dennis;
Bob H
HTML Version:
Text Version:
Subject: Nose Gear
Sent from an IPad
Dennis.
AD pulsar XP
N375CM
Greg
Sent from an IPad
Dennis.
AD pulsar XP
N375CM
Subject: Nose gear
Dennis
Sent from an IPad
