rehn(at)rockisland.com Guest
Posted: Tue Apr 30, 2013 7:57 am Post subject: Rubberhoses, repacement? |
I am a little past the 5 year plus time for rubber replacement. I replaced all the fuel lines about 6 years ago with high pressure auto fuel injection hose. Stuff still looks good, but? Any advice here? Also replaced coolant hoses with silicone about same time. The large radiator hoses were replaced with rubber. Would like to get silicone for the radiator as well. Source?
Thanks for help.
Jerry Rehn
Mono XS 914
12 years running
pjlevi(at)gmail.com Guest
Posted: Tue Apr 30, 2013 8:31 am Post subject: Rubberhoses, repacement? |
Jerry
I recommend you contact Stefan Ingemarsson in Sweden. He advertises in Europa Flyer Magazine (page 14 of March 2013 issue). His e-mail address is stefan.ingemarsson(at)gmail.com (stefan.ingemarsson(at)gmail.com). There are pictures of the hoses in the magazine advertisement.
I recently ordered radiator blue silicon hoses from him and they arrived within 2 days of order and payment by PayPal and he replied very promptly to my e-mail enquiry re prices and delivery.
Philip
G-BWWB, Europa Monowheel Classic, Old Warden
Philip J. Levi, FCA, CTA(Fellow), TEP, MRIN, ARAeS
Chartered Accountant, Chartered Tax Advisor.
E-mail: pjlevi(at)gmail.com (pjlevi(at)gmail.com)
On 30 April 2013 16:56, Jerry Rehn <rehn(at)rockisland.com (rehn(at)rockisland.com)> wrote:
Thanks for help.
Jerry Rehn
Mono XS 914
12 years running
arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
budyerly(at)msn.com Guest
Posted: Tue Apr 30, 2013 7:28 pm Post subject: Rubberhoses, repacement? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jerry,
A UK supplier (at a very reasonable price) is now supplying silicone hoses to Europa for the XS. I have worked with both the Swedish company's product (a bit costly) which is now popular, and our new hoses. Call or email Karen. I think I just bought them out of their last stock. More on the way very soon.
As far as on the engine, Rotax wants an arm and a leg for their heater hose. In the US I use either manufacturer recommended or better hose. I am afraid that even as a certified Rotax repair type, I prefer to buy 5/8 inch silicone hose from my supplier at Amazon Hose. It is great stuff and only $6 a foot rather than $20 per foot and frankly it is just rubber heater hose.. Don't just buy any hose. I tested the Amazon hose stuff and it is good over 300F, under pressure. I even took a torch with a 1500 degree tip to it and it just glows, the outer skin turns to white ash and doesn't burn. It is as thick as the rubber hose (rather than the real thin style silicone that is also available) so you can use your existing clamps. The Rotax hose burns with gusto on direct flame contact. I still use heat sleeve by thermo king to protect my hose from potential exhaust leaks which will cause a burn through in minutes with the rubber hose even with heat shielding.
I can't find 11 mm hose for the crossover tube so I do buy that from Rotax. The 1/2 inch vacuum line or Aeroquip 332 is a little too loose, and vacuum silicone hose of 3/8 or 7/16 is just too tight and won't pop off. So I pay $20 for a foot of it.
The same for the 4 mm line for the carbs, fuel pressure regulator etc. Only because I can reuse the clamps. If you want, you can find 4mm vacuum / suction line but you will need new clamps as it will be thicker than the 7mm OD Rotax line.
At 6 years I think you should look at your lower ignition wires also. Mine were baked. Especially between the cylinders.
As for the the fuel hose. The tried and true method is to check your clamps. If you note your clamps are loose and the hose has shrunk, has cracks on the end not under the clamp or has taken a set (gotten hard) take about 4-8 hours and change it all out. The R-7 hose from six years ago has been replaced with better hose. Available now is Goodyear EP SAE R-9 hose, Gates has an R-14 hose designed for carburation up to 50 psi and is cheaper than the fuel injection hose by about half. Both are impervious to the smell of auto gas, are lined, and reinforced internally. The Gates is also quite flexible. However, the new silicone like inner liner on each brand when pushed on really sticks. So, pre-lube it and plan well.
NAPA auto is a good place to look. Just make sure you get the carbureted hose, not CARB (California Air Resources Board) fuel injection hose which is quite stiff... My NAPA store locally carries both types.
I pull my fuel tank bosses off and flush my tank. Replace the 1 inch hose with marine fuel line or exhaust line (Blue Stripe).
I also check my cobra neck (that rubber 55 degree elbow) for hardness. If it feels like solid plastic, it goes. I normally manufacture a 55 degree aluminum 2 inch elbow and use two inch marine exhaust hose to clamp it into my inlet.
Finally, the site gauge and vent lines need a good looking at also. They get quite brittle as we use cheap hose, and rarely get changed as we figure they are only vent lines and don't give a second thought to them. Don't buy cheap here either. Not all polyurethane lines are created equal. Europa has the good European hose that doesn't crack or get brittle. Amazon hose has crap for urethane normally. My store has the good stuff. We are using tygon in one plane to try it out. It now comes in many colors and is resistant to getting dark with age and is supposed to be 100% safe with ethanol, autogas, or aviation gas.
Bud Yerly
Tech Support.
Posted: Thu May 02, 2013 5:03 pm Post subject: Rubberhoses, repacement? |
Thanks for help, I am presently working my way through all this. Looking forward to flying soon.
Jerry
Sent from my iPad
On Apr 30, 2013, at 8:27 PM, "Bud Yerly" <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote] (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; } P.MsoNormal { FONT-SIZE: 12pt; FONT-FAMILY: "Times New Roman"; MARGIN: 0in 0in 0pt } LI.MsoNormal { FONT-SIZE: 12pt; FONT-FAMILY: "Times New Roman"; MARGIN: 0in 0in 0pt } DIV.MsoNormal { FONT-SIZE: 12pt; FONT-FAMILY: "Times New Roman"; MARGIN: 0in 0in 0pt } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } SPAN.EmailStyle17 { FONT-FAMILY: Arial; COLOR: windowtext; mso-style-type: personal-compose } DIV.Section1 { page: Section1 } <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jerry,
Bud Yerly
Tech Support.
