Pre-Purchase Inspection, Firstar
PostPosted: Tue Jun 25, 2013 11:23 am    Post subject: Pre-Purchase Inspection, Firstar Reply with quote
And then there is the question of will you use it? You're in
an emergency situation where things have gone to junk as a
result of your action or inaction and now according to the
BRS theory you will do something you have never practiced,
cannot preflight for, and do not know the outcome of should
you do it.
Rick Girard
Rick G/Kolbers:
Yes, I would use my BRS if the need arises.
I practice and have engrained into my mind what to do should
the need arise.
I also preflight the system, ensuring the safety pin is
removed and the bridals are in good shape.
I have faith in the system.
Quite a few folks have died because they never thought of
their parachute before they hit the ground. When something
catastrophic happens, one must react instantly in most
cases. A split second may make the difference between
success and failure, life and death.
Some situations the parachute probably will not save you,
such as the recent crash Rick G mentioned. No matter, if I
wasn't flying, I would not hesitate to pop the chute.
Rock House, Oregon - Two time member of the Caterpillar
Club.
WhiskeyVictor36(at)aol.co
PostPosted: Tue Jun 25, 2013 11:50 am    Post subject: Pre-Purchase Inspection, Firstar Reply with quote
John h
And just what is this Caterpillar Club?
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 6/25/2013 3:23:18 P.M. Eastern Daylight Time, jhauck(at)elmore.rr.com writes:
Club.
rowedenny
PostPosted: Tue Jun 25, 2013 1:14 pm    Post subject: Pre-Purchase Inspection, Firstar Reply with quote
Hitting the silk, poping the chute.
Dennis "Skid" RoweMk3, 690L-70, Leechburg, PA
On Jun 25, 2013, at 3:49 PM, WhiskeyVictor36(at)aol.com (WhiskeyVictor36(at)aol.com) wrote:
[quote] John h
Bill Varnes
Audubon NJ
In a message dated 6/25/2013 3:23:18 P.M. Eastern Daylight Time, jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com) writes:
Club.
PostPosted: Tue Jun 25, 2013 1:17 pm    Post subject: Pre-Purchase Inspection, Firstar Reply with quote
http://www.merkki.com/caterpillarclub.htm
Bill:
The above URL will explain the Caterpillar Club.
Membership is free. Wink
Bill Varnes
[quote] [b]
