icom i200 squelch
bobnoffs
PostPosted: Fri May 10, 2013 1:28 pm    Post subject: icom i200 squelch Reply with quote
here's the update on my noise problem. i pulled the radio and got at the circuit board adj. for squelch. turned the plastic screw from 12 oclock to 9 oclock. that totally eliminated the awos broadcast unless i pulled the volume knob to cancel squelch. turned the screw bach to 11 oclock and that seemed to fix my problem. no more noise at higher rpm.
 thanks for the help.
 bob noffs
