Preheating glass cloth
tonyrenshaw268(at)gmail.c
PostPosted: Wed May 22, 2013 2:27 pm    Post subject: Preheating glass cloth Reply with quote
Hi, I'm laying up here in Sydney in temperatures that have recently turned towards our winter. I'm using West Systems which already does not wet out the cloth as well as the SP Systems, and has a shorter pot life, albeit in warmer weather. I'm preheating the job area, the Lift Pin external reinforcement lay ups, and mixing the resin and hardener under workshop spotlights that generate a lot of localised heat. The glass cloth though is cold, and I am wondering about placing it in foil in the oven to heat it up pre layup. I even thought of microwaving it, when my wife isn't at home. Any thoughts on the wisdom or otherwise of doing this? I want to make the cold cloth as conducive as possible to allow ingress of the resin into the individual fibres of a single thread, as I occasionally have had some small splinter strait ions in these layups that appear to be micro dry areas along certain fibres, but the matrix between them is fully wetted out. Thanks in anticipation.
Tony Renshaw
rlborger(at)mac.com
PostPosted: Wed May 22, 2013 2:38 pm    Post subject: Preheating glass cloth Reply with quote
Tony,
Forget the microwave. It won't heat glass cloth. Microwaves heat the water content of items. No water content to fiberglass cloth. At least there better not be any water in the cloth.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On May 22, 2013, at 5:26 PM, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Tony Renshaw
rparigoris
PostPosted: Wed May 22, 2013 3:35 pm    Post subject: Preheating glass cloth Reply with quote
Hi Tony
Warm up Resin and hardener a little, apply mixed resin to cloth on a plastic sheet, use heat gun to warm up all, then squeegee off excess, warm up target area with heat gun if needed.
You can layup cloth with Redux like this if you are adhering to metal.
When filling with plastic or glass balloons, if you mix really really dry, you can do last pass with a heated spackle type knife after you heat the dry mix and can usually get done what many think are impossible.
Ron Parigoris
jrgowing(at)bigpond.net.a
PostPosted: Wed May 22, 2013 7:03 pm    Post subject: Preheating glass cloth Reply with quote
Tony
IF you can't have a warm immediate work area, you should be able to have a
warm cupboard in which to keep the roll of glass?
Bob Gowing (down near Vic Border)
nigel_graham(at)m-tecque.
PostPosted: Thu May 23, 2013 2:07 am    Post subject: Preheating glass cloth Reply with quote
Tony, ideally you need to aim to achieve a stable working environment (workshop and airframe) temperature of around 25c.
Both the resin and the cloth benefit from storage in warm dry conditions. If the cloth is old or has been left in a damp atmosphere, the sizing deteriorates with a result that it will not wet-out properly, you will recognise this by the white “dry” areas within the filaments of the laminate. That is why the build manual recommends heating the cloth storage cabinet with a low wattage light bulb.
If in any doubt, buy some new cloth (and never fold it as the crease will “set”).
Trying to wet-laminate with viscous resin is a pain and usually results in heavy “resin-rich” laminations, you can warm it to thin it, but this reduces its pot life – also a pain. Most of my experience has been with the SP Systems (now Gurit) resin and I found that the slower hardener was far less viscous, giving the double benefit of a longer working-time and much more satisfying to work with. Check the West Systems datasheets to see if less viscous hardeners are available.
Lastly, if you need to use localised heat, do so with care. The gentle warmth from a hair dryer is fine but the vicious heat from a hot-air gun or paint-stripper will almost certainly destroy or distort the work-piece. At best it can cause localised exothermic reactions, which will render the job unusable.
The trick is to prepare everything the day before - warm the workshop, lay out everything you need. When you've finished, drop the brush into a pot of vinegar (much cheaper than Acetone) and just leave everything alone (don't attempt to clean up - you'll just spread the goo over everything. Just walk away. The next day when everything had dried, you can clean up easily.
Good luck!
Nigel
Normal 0 <![endif]-->
Normal 0 <![endif]--> On 22/05/2013 23:26, Tony Renshaw wrote:
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com> (tonyrenshaw268(at)gmail.com)
cipatio
n.
Tony Renshaw
