Carb float settings Rorax 9xx
rehn(at)rockisland.com
PostPosted: Sun Jun 02, 2013 9:10 am    Post subject: Carb float settings Rorax 9xx Reply with quote
Carl
I am resending this email, didn't want to take before?
Carl
I have just spent the last three weeks fighting carb issues and also installed the overhaul kit. I also installed new carb bowls as mine were deformed from over torque on the attachment bolt. I have also replaced the attachment bolt for the car bowl with the new type and oring. The new bolt has a recess for the oring and therefore holds the oring in place! I was unsure about the distance for the float arms as well. I reinstalled the old ones and measured the distance from the center of the arm to the flat area of where the main jet assembly is screwed in. So the carb is sitting upside down for this measurement just like the manual shows if you had the special rotax measuring device. Anyway I did see that they are parallel to the body, your can see this pretty well. I also measured from the center of the arm up to the carb flange that is right next to the arm and is a reference point to see if the arm is parallel. That distance was 11mm. I put the new arms back on and tweaked them so that they also are the same as old or 11mm. That puts them parallel also. This worked for me. My engine was running very rough at about 3000 rpm and then would bog down before the carb overhaul. After the overhaul I could move thru the rough area and smooth out again.
I went thru the mechanical balance and pneumatic balance,this helped but still had rough spot. From my rotax class they had a trouble shooting method for carbs. Set the rpm at 2000 after engine is warm, then slowly pull the carb choke out. The rpm should rise about 400 to 600 rpm then bog. That would be normal for main jet setting. Mine only gained 200 rpm which indicates to lean a setting. I moved main jet needles on each carb to a richer position, lowered the clip on each carb which raise the jet to a richer setting. Ran the engine and was much better and the rough spot went away. Long story but my engine is now running smooth again thru all ranges.
But I still have a separate issue with my yellow caution lite blinking. The rotax folks want me to send it (tcu) in for a diagnosis, looks like I will be doing that Monday. The light starts to blink at about 2300rpm and will stop if throttle down and then start again as rpms rose to about 2300. Even with the engine not running the lite will come on when the throttle is advanced and extinguish when pulled back. So looks like the throttle position sensor is working but maybe not correct or the tcu is not working. This issue was there before I overhauled the carbs so is not due to the overhaul.
I will start a new thread on this issue.
I will try attach a photo of the attachment bolt.
Good luck Carl.
Jerry
