aerobiz1(at)gmail.com Guest
Posted: Thu May 30, 2013 5:46 pm Post subject: Offset pistons in Brand "L," "C" or "F"? |
Hi Frank,
There has been a lot of discussion on the Jabiru engine list on this subject. It started when someone couldn't work out which way the pistons should be fitted. Â Most engines have piston pin offset, mainly to reduce piston slap at TDC hence noise. Â Some racing types reverse it to try and get a little more torque, while others 'desax' the bore by offsetting the barrels/cylinders relative to the centreline of the crank, ie. moving the cylinders forward or backwards a few millimetres in the same plane, not rotating around the crank as in a v-twin or radial. Â In a motorcycle production racing class I was involved in, a guy got caught cheating by doing just this. Â He moved the entire cylinder bank on a Suzuki 1000cc four cylinder engine !
Marty
On Fri, May 31, 2013 at 11:31 AM, Frank Roskind <frankroskind(at)hotmail.com (frankroskind(at)hotmail.com)> wrote:
[quote] Thanks for your response. Â I have googled offset piston with lycoming, continental and franklin, but found nothing relevant except a reference to the Franklin automobile having offset piston pins. Â After your message I also googled the same three with "desaxed" and found nothing relevant. Â It seems like a great idea, given all the fooling around with exhausts, intakes and ignition, it is kind of odd that I am not reading of anyone who took a shot at offsetting the pistons.
 Maybe I just found a great retirement occupation.
Date: Fri, 31 May 2013 06:58:04 +1000
Subject: Re: Offset pistons in Brand "L," "C" or "F"?
From: aerobiz1(at)gmail.com (aerobiz1(at)gmail.com)
To: frankroskind(at)hotmail.com (frankroskind(at)hotmail.com)
Frank , this has been discussed at length. Â Many engine types use offset piston pins or 'desaxed' bores. Harleys for example. Try Googling either term.....
Marty
vettin74(at)yahoo.com Guest
Posted: Thu May 30, 2013 6:13 pm Post subject: Offset pistons in Brand "L," "C" or "F"? |
Jabiru uses offset pistons. They way to tell which way they go in the bore is by a mark on the piston face. Either an arrow(new engines) or a very small half moon shaped indent which denote the end of the engine with the prop on it.
Maybe that was overed didnt see it in his thread.
Nick
Sent from my pocket
On May 30, 2013, at 8:45 PM, Martin Hone <aerobiz1(at)gmail.com (aerobiz1(at)gmail.com)> wrote:
[quote]Hi Frank,
There has been a lot of discussion on the Jabiru engine list on this subject. It started when someone couldn't work out which way the pistons should be fitted. Most engines have piston pin offset, mainly to reduce piston slap at TDC hence noise. Some racing types reverse it to try and get a little more torque, while others 'desax' the bore by offsetting the barrels/cylinders relative to the centreline of the crank, ie. moving the cylinders forward or backwards a few millimetres in the same plane, not rotating around the crank as in a v-twin or radial. In a motorcycle production racing class I was involved in, a guy got caught cheating by doing just this. He moved the entire cylinder bank on a Suzuki 1000cc four cylinder engine !
Marty
| Quote: | Thanks for your response. I have googled offset piston with lycoming, continental and franklin, but found nothing relevant except a reference to the Franklin automobile having offset piston pins. After your message I also googled the same three with "desaxed" and found nothing relevant. It seems like a great idea, given all the fooling around with exhausts, intakes and ignition, it is kind of odd that I am not reading of anyone who took a shot at offsetting the pistons.
Frank , this has been discussed at length. Many engine types use offset piston pins or 'desaxed' bores. Harleys for example. Try Googling either term.....
Marty
st">http://www.matronics.com/Navigator?JabiruEngine-List
cs.com
matronics.com/contribution
BARRY CHECK 6
Posted: Fri May 31, 2013 5:10 am Post subject: Offset pistons in Brand "L," "C" or "F"? |
Marty:
I do not know about Suzuki or Harley - But I do know about Lycoming and Continental - They DO NOT HAVE ANY PISTON OFFSET.
I know of NO reason to have the wrist pin offset - It just does NOT make ANY sense at all. There are Front & Rear to some pistons but that is because of piston dome designs and valve clearances.
Think of it this way: What CENTERS the piston in the center of the cylinder?
THE RINGS!!!
So, how or why would there be a wrist pin offset?
If there was piston pin offset, then the rings would be offset also - And that would lead to uneven wear and loss of compression.
Whomever started this Wives Tail should be SHOT with Dumb-Dumbs because it would match their intellect.. Always REMEMBER B.S. is spread at the speed of an electron on the internet.
Barry
"Do you know why pilots think they are mechanics? Because they can but tools at Home Depot."
On Thu, May 30, 2013 at 9:45 PM, Martin Hone <aerobiz1(at)gmail.com (aerobiz1(at)gmail.com)> wrote:
[quote] Hi Frank,
Marty
Marty
| [b]
matronics(at)rtist.nl Guest
Posted: Fri May 31, 2013 7:17 am Post subject: Offset pistons in Brand "L," "C" or "F"? |
Barry, before lashing out like this and having people shot for sending information, perhaps you should read up on Piston slap.
If it were an old wives tail, then no engine manufacturer would bother to put an orientation in their manual, don't you think?
On 5/31/2013 3:09 PM, FLYaDIVE wrote:
[quote]Marty:
THE RINGS!!!
Barry
| Quote: | Hi Frank,
Marty
Marty
| [b]
zeprep251(at)aol.com Guest
Lynn Matteson
Posted: Sat Jun 01, 2013 2:33 am Post subject: Offset pistons in Brand "L," "C" or "F"? |
Easy, big boy, easy....
Nobody says that the pistons are off-center....where did you get THAT
idea?? It is the piston pins that are offset in SOME pistons, used
in SOME applications, in SOME engines.
The pin offset is done to change the angle that the connecting rod
makes with the crankshaft during part of the cycle. It is also there
to change the relationship of the piston within the cylinder bore at
certain times, to make the engine quieter....this "noise" being the
so-called "piston slap" that occurs when the piston skirt hits the
cylinder wall near the top of its stroke. These are simplified
explanations of why there is piston pin offset. No point in trying to
explain it any further...I wouldn't know how, and it might not be
understood if I did.
Lynn Matteson
| Quote: | Kitfox IV Speedster, taildragger
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1445 hrs... (since 3-27-2006)
On May 31, 2013, at 9:09 AM, FLYaDIVE wrote:
| Quote: | Marty:
cylinder?
THE RINGS!!!
Barry
On Thu, May 30, 2013 at 9:45 PM, Martin Hone <aerobiz1(at)gmail.com>
wrote:
Hi Frank,
Marty
Marty
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
