Throttle Stops
carl(at)flyers.freeserve.
PostPosted: Thu May 30, 2013 12:23 am    Post subject: Throttle Stops Reply with quote
I seem to recall in the early days of Europa that the PFA dictated that we should install a physical throttle stop on the throttle lever (in the cockpit).
I have never really understood the purpose of this as the carburettors have their own stops as IMHO one seems to fight against the other. As soon as you increase the idle RPM using the adjuster screws on the carb, the throttle lever is pulled forward by the cables, moving the lever away from the cockpit stop.
We have flown quite happily with the carb stop limiting the slow running with a gap of about 2 mm between the rear of the throttle lever and the stop block (tufnol). However, we have just overhauled the carbs and are resetting the balances etc so were wondering if this omission needs to be addressed – it would just be a matter of elongating the holes in the throttle stop.
Reading through various articles on Rotax/ Bing carburettor balancing I note that these also stress the need for a cockpit end stop but give no explanation as to why.
I’m sure there is a good reason, just need someone to cast some light on this.
alanb(at)dpy01.co.uk
PostPosted: Thu May 30, 2013 12:33 am    Post subject: Throttle Stops Reply with quote
Carly,
From the Rotax Installation Manual, Page 2-4.
"The addition of a throttle-closed stop is important to avoid the possibility of excess tension on the throttle cable causing loss of throttle control"
Alan
#0303
On 30 May 2013, at 09:22, Carl Pattinson <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)> wrote:
kingsnjan(at)westnet.com.
PostPosted: Thu May 30, 2013 2:48 am    Post subject: Throttle Stops Reply with quote
<<<< I’m sure there is a good reason, just need someone to cast some light on this.
Carl,
My understanding is that if there is no throttle stop on the throttle lever, it is possible to deform the throttle stops on the carburettors if one pulls back too hard on the throttle lever.
Cheers
Kingsley in Oz.
Duncan McFadyean
PostPosted: Fri May 31, 2013 11:53 pm    Post subject: Throttle Stops Reply with quote
Whilst complying with the LAA requirement for a throttle stop, it's useful to set up the cables so that the carb stops are reached first, followed closely by the stop on the throttle lever itself if the lever is deliberately pulled closed against the throttle lever stop. This limits any excess strain that can be applied to the cables, but provides a useful facility to temporarily pull down the idle speed in flight (which in any case will still always be well above the static setting, as the forward motion drives the prop). As soon as the deliberate backpressure on the lever is released, 'normal service' is resumed
This facility makes a usefully large addition to rate of descent and is helpful for landing in to short strips; it's like having an airbrake!
Duncan McF.
dg.watts(at)talktalk.net
PostPosted: Sat Jun 01, 2013 12:21 am    Post subject: Throttle Stops Reply with quote
Duncan,
You've got me there. Surely if you have already pulled the throttle back to the stop on the carb., pulling the lever any more will not make any difference at all. Unless I am missing something.
Dave Watts
G-BXDY Classic Monowheel (Still just short of 2000hrs. But at least we are now flying again from our previously waterlogged airfield, so another week should see us over the magic number, and loving every minute of it)
On 1 Jun 2013, at 08:52, "Duncan & Ami" <ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net)> wrote:
[quote] Message (at)font-face { font-family: Helvetica; } (at)font-face { font-family: Cambria Math; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: Consolas; } (at)page WordSection1 {size: 612.0pt 792.0pt; margin: 72.0pt 72.0pt 72.0pt 72.0pt; } P.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } LI.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } DIV.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } PRE { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New"; FONT-SIZE: 10pt; mso-style-priority: 99; mso-style-link: "HTML Preformatted Char" } SPAN.apple-style-span { mso-style-name: apple-style-span } SPAN.HTMLPreformattedChar { FONT-FAMILY: "Consolas","serif"; mso-style-priority: 99; mso-style-link: "HTML Preformatted"; mso-style-name: "HTML Preformatted Char" } SPAN.EmailStyle20 { FONT-FAMILY: "Calibri","sans-serif"; COLOR: #1f497d; mso-style-type: personal-reply } .MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.WordSection1 { page: WordSection1 } <![endif]--> <![endif]--> Whilst complying with the LAA requirement for a throttle stop, it's useful to set up the cables so that the carb stops are reached first, followed closely by the stop on the throttle lever itself if the lever is deliberately pulled closed against the throttle lever stop. This limits any excess strain that can be applied to the cables, but provides a useful facility to temporarily pull down the idle speed in flight (which in any case will still always be well above the static setting, as the forward motion drives the prop). As soon as the deliberate backpressure on the lever is released, 'normal service' is resumed
Duncan McF.
richard collings
PostPosted: Sat Jun 01, 2013 3:41 am    Post subject: Throttle Stops Reply with quote
Hi My understanding of this is that if you over travel the throttle lever when closed you can unseat the cable outer from its carburettor bracket. To reduce this possibility we are required by LAA to wire lock the outer cable to that bracket and fit a throttle lever stop in the cabin. Regards Richard
Sent: Thursday, May 30, 2013 9:32 AM
To: Europa Forum Forum (europa-list(at)matronics.com)
Subject: Re: Throttle Stops
Carly,
Alan
#0303
nigel_graham(at)m-tecque.
PostPosted: Sat Jun 01, 2013 4:11 am    Post subject: Throttle Stops Reply with quote
+1
Confused of Southampton
On 01/06/2013 09:21, David Watts wrote:
[quote] Duncan,
Dave Watts
Duncan McF.
Gilles.Thesee(at)ac-greno
PostPosted: Sat Jun 01, 2013 8:12 am    Post subject: Throttle Stops Reply with quote
resumed
Duncan and all,
In my opinion, an adjustable stop at the throttle lever is important for
2 things :
- Allowing an easy fine tuning of the idle speed without disturbing
anything in the engine compartment
- Preventing any stress on the throttle linkage and carb, which is the
principal cause of changes in idle adjustment and carb synchronization.
I crafted a webpage which may be of interest
http://contrails.free.fr/engine_rotax_stops.php
French only for the moment, but a Frenglish version might appear soon...
FWIW,
Best regards,
Gilles
PostPosted: Sun Jun 02, 2013 1:02 am    Post subject: Throttle Stops Reply with quote
It does make a difference – on our setup with the engine idling normally (carb throttle arm touching the carb stops)  we get 2,000 RPM – apply back pressure and the RPM drops to 1,700 RPM – release pressure and the RMP goes back up. The distance between the throttle lever and the backstop is about 2 – 3 mm when no pressure applied.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of nigel_graham(at)m-tecque.co.uk
Sent: 01 June 2013 13:11
+1
Duncan,
Dave Watts
Duncan McF.
[/b]< Â Â Â Â  - MATRONICS WEB FORUMS via the Web    --> http://forums.matronics.com[/url]         - List Contribution Web generous  Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â  -Matt http://www.matronics.com/c=[/b]
Duncan McFadyean
PostPosted: Sun Jun 02, 2013 1:30 am    Post subject: Throttle Stops Reply with quote
Dave,
You're missing the elasticity of the throttle stops on the carbs (just bent bits of mild steel), which are sufficiently springy to drop idle rpm by a couple of hundred.
DMcF.
Duncan McFadyean
PostPosted: Sun Jun 02, 2013 1:47 am    Post subject: Throttle Stops Reply with quote
I should add that it also makes a big difference to the smoothness of engine shutdown; switch off one mag, pull back on throttle lever just as rpm dips then switch off the other mag. The engine slows to a graceful stop.
DMcF.
Duncan McFadyean
PostPosted: Sun Jun 02, 2013 1:48 am    Post subject: Throttle Stops Reply with quote
Carl,
Thank you for understanding my email, no pills needed!
DMcF
richard collings
PostPosted: Mon Jun 03, 2013 4:16 am    Post subject: Throttle Stops Reply with quote
Hi Sorry I have got it wrong again , with the throttle sprung to open the cabin throttle closed stop is fitted to ensure you don’t over load the levers on the carburettors by attempting to travel them beyond their stops. By the sound of it if you can apply extra load to the closed lever and achieve a lower RPM idle then you must be loading the linkage and taking up any slight play in the carburettors cross shaft. Not good I think. With regard to not wanting to over travel the throttle lever when fully open, I fitted a stop in the cabin because I found that you could unseat the outer cable at the carburettor end by over traveling the throttle lever to open and did not want to rely on just the wire locking to stop this.
Sorry again for my mistake which I realised when I checked the engine yesterday.
Regards to all .
Richard
Europa XS G-CGZV 45Hrs plane flying very well, Pilot rubish.
Sent: Sunday, June 2, 2013 10:48 AM
Subject: RE: Throttle Stops
Carl,
DMcF
