Posted: Fri Jun 07, 2013 7:31 am Post subject: Chinese vs YAK |
Cory this is the check valve setup for the pop off valve assembly for my YAK 50. Takes a little patience but the old YAK check valves can be removed from the pop off valve to rebuild the system. Since the pictures are on my iPad I will send them as singletons. Doug has a pop off valve manifold that will work also. You just have to mix and match. The metric male and female fittings are the same. The guts are not interchangable.
Doc
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
33.58 KB |
811 Time(s) |
