		richard.goode(at)russiana Guest
				 Posted: Mon Jun 12, 2006 9:32 am    Post subject: M14R etc |
				To follow on from  Jerry Painter’s posting about M14R, and to clarify:
 We have the  somewhat Russian position of having two higher-powered engines being made in the  same city in Russia, but with rather different designs.
 The M14R is  carburetted and gives 450-hp.
 The US Airflow  system works well on the M14P family of engines but does need careful setting up  to operate efficiently.  Also there  are complications in terms of needing a higher-powered fuel pump; an electrical  fuel pump for starting and for emergency use, as well as some aircraft  changes.
 We have run one  M14PF (400-hp), and also an M14R with Airflow fuel injection, and giving very  good results.  We would estimate at  least 480-hp with the M14R, and quite astounding rate of climb in an Su-26.
 The M9F delivers  435-hp in carburetted form.  The  fuel injection version is not in production, but is giving 450-hp, and probably  more before production standard is established.
 If anyone wants  more information on these engines do contact us.
   Richard  Goode
 Richard Goode Aerobatics
 Rhodds  Farm
 Lyonshall
 Herefordshire
 HR5 3LW
 United Kingdom
  Tel:    +44 (0) 1544 340120
 Mob:  +44  (0) 7768 610389
 Fax:   +44 (0) 1544 340129
 www.russianaeros.com
		schwartzcompany(at)worldn Guest
				 Posted: Mon Jun 12, 2006 11:08 am    Post subject: M14R etc |
				Hello:
  Do any of these new Russian M14 engines with the  higher HP, improve the cruise performance on a standard YAK 52?
  Robert E. Schwartz
 President
 THE SCHWARTZ COMPANY  MIDWEST
 Commercial Real Estate Services
 2406 East Pleasant  Street
 Davenport, Iowa USA 52803
 Tel: (563) 322-2228  Fax: (563)  359-7769 Cell: (563) 940-8600
 Email: schwartzcompany(at)worldnet.att.net (schwartzcompany(at)worldnet.att.net)
  This information is intended for the use of individual named above.   If you are not the intended recipient, you are hereby notified that any  disclosure, copying, distribution, or the taking of any action in reliance on  the content of this information is strictly prohibited.
  [quote]   ---
				 Posted: Mon Jun 12, 2006 11:51 am    Post subject: M14R etc |
				Robert,
  Get a 50. They are slicker than greased owl #$^%. You'll get 20 to 30 clicks faster cruise at Nominal 1 or 2 burning 11 - 12 gallons/ hour. And they climb like home sick angles.
  Doc
		johnhilterman1(at)cox.net Guest
				 Posted: Mon Jun 12, 2006 4:09 pm    Post subject: M14R etc |
				And I have one for sale.  Immaculate 1984 YAK-50 listed on Barnstormers and Trade-a-Plane.
 Hitman
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Roger Kemp
  Sent: Monday, June 12, 2006 2:50 PM
  To: yak-list(at)matronics.com
  Subject: Re: M14R etc
 Robert,
 Doc
		cpayne(at)joimail.com Guest
				 Posted: Tue Jun 13, 2006 3:00 am    Post subject: M14R etc |
  >Hello:
 Robert E. Schwartz
  Robert, it has been reported that the Yak-18T gains performance from this engine by allowing a higher altitude cruise, should work for the -52, just add O2 . OTOH, the -TD conversion, a tailwind and a downhill glideslope  are the only other known ways to speed up a Yak-52. Perhaps a gaggle of Geese hitched to each wingtip :>)
  Craig Payne
  cpayne(at)joimail.com (cpayne(at)joimail.com)
		jimscjs(at)mbay.net Guest
				 Posted: Tue Jun 13, 2006 7:40 am    Post subject: M14R etc |
				A rocket engine would not help the Cruise on the  52.
  Jim
  [quote]   ---
		fish(at)aviation-tech.com Guest
				 Posted: Tue Jun 13, 2006 8:04 am    Post subject: M14R etc |
				Jim,
 I would like to disagreee, the F-4 proved with enough power even a brick can
 fly!
 With a rocket you would gain a large cruise advantage, for a short time.
 About a month after completing AF Flight Engineer School for C-130, I got a
 ride on the Blue Angeles C-130 (Fat Albert). I was on the flight deck when they
 lit off their JATO bottles. The C-130 gained the most perf I had seen in a C-130
 yet, and then went on to do things I did not beleive the 130 could do.
 I am glad that I had that opertunity to fly a C-130 that way before deploying
 to Qutar to fly combat missions. When we made our first landing at bagdad international
 airport, it was like I was back on Fat Albert, only this time I was the Engineer
 responsiable for the aircraft.
 Fly Safe
 John Fischer
 Jim
