Posted: Mon Jul 08, 2013 12:29 pm Post subject: Low voltage indicator with dual alternators |
| Quote: | My operational goals for the Z-14 included being able to run much of the panel
on one battery while still having a fully charged battery for starting. The
idea being that I wanted to be able to enter flight plans and even check weather
before engine start. That's worked out well. I can connect the buses for starts
if needed and that works well as well. |
Okay, but consider the ENERGY needed to do these two tasks.
Suppose you turn on three electro-whizzies for a total drain
of 3A (a lot for solid state gizmos) and take 5 minutes to
herd all the ducks into place. That 12v x 3A x 300 seconds
for a total of 11,000 watt-seconds.
Now, lets crank the engine at 200A x 12v x 10 seconds
for a total of 24,000 watt-seconds.
How much energy is available for use in a 18 a.h.
SVLA battery? At a 3A rate will give it up over 5 hours
at an average voltage of 11.5 for a total of about 650,000
watt-seconds.
In other words, the task of conducting pre-flight activities
and starting the engine are not big demands on a well
maintained battery.
However, I normally start with the buses separated because if I go parallel, the voltage drop causes my 3 MDFs to re-boot. |
How much 'stuff' do you have to turn on before engine
start? On the Beech products we used to offer a mini-ebus
switch that would let you fire up a comm radio directly
from the battery. Your comm radio probably needs 0.2A receive,
and maybe 1.5A transmit. A long winded pre-flight activity
might need 1000 watt-seconds.
I'm thinking that the bus from which all your 'kitchen
sink' accessories is powered also powers the comm radio
and you have no way to power up the comm radio independently?
You might want to consider moving a comm radio to a
battery bus and adding . . .
COMM RADIO . . . . . Check OFF
. . . . to your shutdown checklist.
Bottom line is that with two batteries on board, you've
got perhaps a million watt-seconds to burn. Doing your
starts in parallel will reduce relative abuse to the batteries
and extend their service life. Letting the 'kitchen sink'
accessories clock in after engine start may not be
a significant delay in your departure plans.
Bob . . . [quote][b]
Posted: Wed Jul 10, 2013 6:30 am Post subject: Low voltage indicator with dual alternators |
On 7/8/2013 4:29 PM, Robert L. Nuckolls, III wrote:
| Quote: | | Quote: | My operational goals for the Z-14 included being able to run much of the panel
watt-seconds.
maintained battery.
| That was my assumption going in. My original thought was that I'd be able to turn everything on, do my flight plan input, clearance copy and whatever, then turn the key and start her up. Thinking there would be little need to manage energy through th pre-start, I do not have an avionics master or bus or even power switches on my MFDs.
The fly in the ointment has been tendency for the MFDs (3 GRT HX units) to reboot during an interconnected start.
The energy draw is probably a bit more than one might expect but I don't have actual current draw measurements to validate. For planning purposes I assumed 4.5A for the 3 MFDs combined, 1A for the dual AHRS, .6A for ADSB weather, 2.1A for the G430. Add 1 amp for the contactor and (unknown) for the panel fans. That's 12v x 8.2A x 300secs = 29,520 watt-secs. That doesn't include the AP and audio panel which are on the same bus and are turned off at shutdown. It is the minimum I want for pre-start duck herding but I'm thinking I need to find a way to mitigate it.
(BTW, Thanks so much for engaging me on this - This has become a big task on my improvement list for the year)
| How much? I need at least one MFD (weather, input of pre-flight values), the G430 (flight plan input & comm). But powering up only 1 MFD is a compromise - 3 are configured. With anything less, many error msgs are generated.
Is all this pre-start duck herding necessary or desirable? Yes and Yes
Virtually 99% of my flying is IFR. Single pilot in and out of the NY/PHL/WASH axis requires lining them up and knocking them down or getting called on every miss. The reality is more nuanced however. In winter, I start it, then begin the flight planning/clearance getting process. No electron problems except that the MFDs sometimes reboot on an interconnected cold weather start. In summer, temperatures demand minimizing the time with the RV10 gull wing doors closed. We're very comfortable sitting in the cockpit fooling around as long as a breeze is blowing thru with the doors providing some shade. Engine start requires the doors be closed and from that point on, it's sweaty and miserable until takeoff despite the strong stream of 'fresh' air blowing on our sun baked carcasses. The net is - I will hurry and/or skip some pre-flight, post-start planning activities until airborne and I invariably pay for that. Actually, I just don't let that happen any longer.
| Done. The SL30 is on the other bus and other non-essential stuff is shut down during shut down, but the whole G430 needs to be online for flight planning. I don't consider it a kitchen sink - just the essentials in this bit intensive world.
It just occured to me that several non-bus essentials aren't even included; the cell phone for remote IMC releases and the iPad. Most NY/WASH/PHL clearances, make that 'all' such clearances, require victor airway translation for G430 input. Entry of the 8-10 step clearance into the iPad is required in order to figure out that actual waypoints for entry into the G430. It's usually desirable to make sure I 'get it' before taking off over NYC and heading toward the Wash SFRA, which means that it then gets mostly input into the G430 before engine start. Ah, the joys of the paper-less cockpit!
| Well, in summer I need the essential sink before start. Point well taken, but no doubt about the need here.
However, I'd like to get back to interconnected parallel starts with all my essential stuff on. I'm thinking the core problem is not the load involved but rather the tendency for the GRT MFDs to re-boot. I started looking at power wiring options for the GRTs. This paragraph from the installation guide may be useful:
| Quote: | The majority of the current flow into the display unit will occur on the bus with the
highest voltage. So if the voltage of the main bus or power source falls below
that of the secondary bus or power supply, the secondary bus will power the
display units and operation will not be interrupted. Since it is desirable to not
have the display units and AHRS connected to the power supply supplying power
to the engine starter during the engine start (to maximize the current available for
the starter, and possibly extend the life of the CCFL backlight in the display unit),
this feature allows the fitting of a small (3-5AH) auxiliary battery to one of the
power input connections provide power to the EFIS during engine start. If an
auxiliary battery is fitted, provisions should be made to keep it charged.
| What do you think?
