ronko(at)att.net Guest
Posted: Thu Aug 08, 2013 8:11 pm Post subject: 582 Stator Coil Problems |
Pulsar Flyers,
Has anybody ever experience problems that seem to stem from the stator coil on a Rotax 582?
My ignition has gone completely flakie. Both mags and ground switches are fine. The rear mag connections for some reason do not fire the rear mag. The front mag white wire for charging the mag is open, should be a ground, so the front mag doesn't fire either. When I provide a separate ground to the white wire on the front mag, it works (plugs spark), sometimes. Sometimes being, I crank the engine and there are times there is continuous spark as the engine cranks as normal and the next time I may (and often) get no spark at all.
Any thoughts, ideas, or similar experiences, please share.
Thanks.
Ron
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
ccoulter(at)wavecable.com Guest
Posted: Mon Aug 12, 2013 11:25 am Post subject: 582 Stator Coil Problems |
Ron
No knowledge on the 582 but on the 912 there was a problem
where both mags failed at the same time. The two wires
that are in a metal sheath shorted out inside the sheath.
That shorted the two wires together.
Clarke
On Thu, 8 Aug 2013 21:09:36 -0700 (PDT)
Ron Koval <ronko(at)att.net> wrote:
| Quote: | Pulsar Flyers,
share.
Thanks.
Ron
