Posted: Sun Jul 07, 2013 1:38 am Post subject: Choosing the switches for an RV-10 |
Guys
It’s time to choose the switches for the RV-10 panel, and I wonder which ones are more popular between the RV-10 builders:
For the Master and ALT field, have you used the Cessna split rocker or just 2 separate toggle switches?
For the magnetos and starter, did everybody use the ACS combined keyed switch, or is it better to use 2 toggles and one push-button momentary starter switch?
And for the lights and other electrical equipment, which has been the choice: the classic rocker switches or the color coded toggle switches?
Thanks for your opinions, both in the technical and the functional aspects
Carlos
Posted: Sun Jul 07, 2013 7:02 am Post subject: Choosing the switches for an RV-10 |
At 04:37 AM 7/7/2013, you wrote:
Guys
The split rocker switch functionality can be
duplicated by a progressive transfer switch
of any other style. There's nothing 'magic'
or extraordinary convenience for having purchase
the split rocker switch.
http://tinyurl.com/kdqwahq
Similarly, there is nothing 'magic' about
functionality of the legacy key-switch . . .
which is expensive and takes up a lot of room
http://tinyurl.com/ch3yly
Your choice as to 'better'. What are your design
goals for appearance, functionality, and cost
of ownership? Is ease of fabrication, installation
and wiring important to you?
Over the years, we've had many discussions about switch selection
on the List. If one surveys the constellation of completed
airplanes in possession of List members it is a certainty
that you will find a broad range of styles.
If it were my airplane, I would go 100% toggle switches
for the following reasons:
Easy to mount in ROUND hole made with spotfacer, stepdrill
or punch. Contrast this with the $time$ and effort to
craft rectangular holes for rocker switches.
http://tinyurl.com/m45n4f7
Functionally interchangeable switches are made by a host
of manufacturers. Rocker switches are manufacturer specific.
Replacing a switch calls for acquiring the same switch
from the same manufacturer.
Here's an exemplar set of switch arrangements
tailored to system complexity.
http://tinyurl.com/ljkw3ju
I suggest the toggle switch fitted with fast-on
terminals represents the lowest cost, greatest
ease of installation and maintenance.
Bob . . . [quote][b]
mrspudandcompany(at)veriz Guest
Posted: Sun Jul 07, 2013 7:47 am Post subject: Choosing the switches for an RV-10 |
[quote] Another thing you might want to keep in mind in your design is that some states / localities require that 2 key accesses be used to enter and start the aircraft. One of the keys can be to access the door / canopy entry and as a second key you might use a simple key switch, in a round hole, and with fast-on terminals, used in series with the start button. A failure of this switch, wired in this configuration would prevent you from starting the aircraft, but would not affect engine operation once it is running.
Roger
rickofudall
Posted: Sun Jul 07, 2013 6:57 pm Post subject: Choosing the switches for an RV-10 |
Carlos, I always use two toggles for the mags, and SPST key switch for the starter contactor and a pushbutton starter switch. It's cheaper if any of them fail and by having the mags separate from the starter switch I can turn the engine over for maintenance or diagnostics without worry that the engine will accidentally start.
Rick Girard
On Sun, Jul 7, 2013 at 10:46 AM, Roger & Jean <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote:
| Quote: | I suggest the toggle switch fitted with fast-on
| Quote: | Another thing you might want to keep in mind in your design is that some states / localities require that 2 key accesses be used to enter and start the aircraft. One of the keys can be to access the door / canopy entry and as a second key you might use a simple key switch, in a round hole, and with fast-on terminals, used in series with the start button. A failure of this switch, wired in this configuration would prevent you from starting the aircraft, but would not affect engine operation once it is running.
Roger
| | Quote: |
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Posted: Sun Jul 07, 2013 7:09 pm Post subject: Choosing the switches for an RV-10 |
At 09:52 PM 7/7/2013, you wrote:
| Quote: | Carlos, I always use two toggles for the mags, and SPST key switch
Good point. I think you've mentioned this before.
I'll try to remember to add it to my list of
PRO-toggle arguments.
bakerocb
Posted: Mon Jul 08, 2013 6:10 am Post subject: Choosing the switches for an RV-10 |
7/8/2013
Hello Carlos, You wrote: “For the magnetos and starter, did everybody use the ACS combined keyed
switch, or is it better to use 2 toggles and one push-button momentary starter switch?”
Given the wiring complexity (confusion) and the widely published poor reliability of the ACS combined starter – magneto switch I am surprised that any amateur builder would even consider installing such a switch in the aircraft that he is building.
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
PS: A more ponderable choice is how to place the switches in the panel. Two schools of thought are: a) Scatter the switches about the panel in some manner that locates the switches close to the instrument or device being controlled (an ergonomic philosophy); or b) Place all (or as many is feasible) of the switches in close proximity so that at one glance one can tell if all switches are either ON or OFF (a visual domination philosophy).
Time: 02:38:19 AM PST US
From: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
Subject: Choosing the switches for an RV-10
Guys
It's time to choose the switches for the RV-10 panel, and I wonder which
starter switch?
Carlos
Posted: Mon Jul 08, 2013 6:43 am Post subject: Choosing the switches for an RV-10 |
OC |
Can you point me to the discussions about this product?
Are reliability issues centered on any one feature
of the design? This switch is a clone of the legacy
Bendix/Gerdes product popularlized in the single-engine
markets waaayyy back when. I think I recall seeing a
twin that needed two-keys to go flying. I'm wondering
if the problems are not centered on starter contactor
currents. The FAA saw fit to mandate adding a diode
to the circuit for airplanes that were being upgraded
to modern, two-stage solenoid/contactors . . . when
in fact, contact opening arcing was just the worst
of stress . . . that 30A inrush was still there . . .
a stress that the switch was never designed to manage.
rv7a.n18pf(at)gmail.com Guest
Posted: Mon Jul 08, 2013 12:05 pm Post subject: Choosing the switches for an RV-10 |
I installed the ACS keyed switch in a homebuilt I finished in 1990. Wiring was straight forward (Bob has a good diagram in the Z figures), and it has given me 23 years of reliable service. I put another one in my most recent project and it has been working fine for four years. So my personal experience does not support your statement below.
It is simply part of the "security theater". As long as you are comfortable, toggle switches will work as well.
YMMV, but the ACS switch has worked fine for me.
Paul A. Fisher
Q-200 N17PF - ~1,400 hours
RV-7A N18PF- ~400 hours On Jul 8, 2013 9:16 AM, "Owen Baker" <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:[quote] 7/8/2013
OC
Guys
starter switch?
Carlos
bakerocb
Posted: Tue Jul 09, 2013 3:09 am Post subject: Choosing the switches for an RV-10 |
7/9/2013
Hello Bob Nuckolls,
On 7/8/13 you wrote: “Can you point me to the discussions about this product? Are reliability issues centered on any one feature of the design?” (See posting copied below.)
On 8/16/2004 You wrote: “Have you considered getting your money back and putting in toggle switches? In my never humble opinion, key-switches suck.” (See posting copied below)
OC
PS: In the interest of brevity I did only one archive search of the aeroelectriclist, using only the search term ACS SWITCH, and selected only one posting of the 16 that showed up.
Time: 07:43:03 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Subject: Re: Choosing the switches for an RV-10
>combined starter ' magneto switch I am surprised
>OC
Match: #3Message: #42083From: <bakerocb(at)cox.net>Subject: Igntion SwitchesDate: Jul 21, 2008 7/21/2008
Hello Skip, You wrote: "I saw the referenced ACS Keyed Ignition Switches and a starter switch. What is the benefit in two switches over one?" I am glad you asked. The history of these types of ignition switches: http://www.aircraftspruce.com/search/search.php does not fill one with great confidence. See: http://tinyurl.com/j3m5j They are mechanical devices, of not necessarily the highest quality -- sort of like an old time watch -- with a lot of little bits and pieces inside that can get worn / broken. Actually I'd prefer three switches. A simple, reliable, separate toggle switch for each magneto P lead, and a push button switch with a guard on it for activating the starter contact solenoid.
See the postings copied below for other's experience with the ACS / Bendix keyed type switches.
-------------------------------------------- {#} Replies are directed back to kisbuilders(at)angus.mystery.com {#} To reply to the author, write to Keith.Miller(at)esa.int OC I started with the standard ACS switch , but junked it after it left one of the mags live after switching off , now I also have 3 seperate switches ( 2 "heavy duty" for the mags and a "push to make" type for the starter ).
----------------------------------------------------------- Message: #19408 Date: Aug 16, 2004 From: "Robert L. Nuckolls, III" Subject: Re: ACS switch issues for Rotax 912S > > >Ok, I traced it down to the ACS ignition switch (P/N A-510-2). When I >switch to the left side ("R") it will cut out sometimes. Not very often >but if I do it just right then off she goes. The switch only had been >used about 40 hours when this started showing up. > >It appears that it is grounding, or at least partially grounding, >inadvertently when switched over to that "mag". > >Could it have to do with the diode issue that ACS mentions with regards to >impulse coupled mags? The diode was added to the starter contactor control circuit . . . with totally bogus engineering behind it. See http://www.aeroelectric.com/articles/spikecatcher.pdf >FWIW I've wired according to Bob's notes with the shield acting as the >ground. I was very very careful when wiring and so far this is the only >electrical problem I've had. > >I've also wiggled all the wires around behind the switch (and also the >engine) and it doesn't seem to be any of the wires. I'm guessing it's >internal to the switch or something to do with a spike of some sort. > >Any other ideas before I pull the switch out and send it back to ACS? Have you considered getting your money back and putting in toggle switches? In my never humble opinion, key-switches suck. Bob . . .
Posted: Tue Jul 09, 2013 4:32 am Post subject: Choosing the switches for an RV-10 |
Thank you all for your opinions, I ‘m still undecided but I think I will follow the toggle route.
Best
Carlos
Guys
starter switch?
Carlos
01234567890123
Posted: Tue Jul 09, 2013 6:12 am Post subject: Choosing the switches for an RV-10 |
At 06:08 AM 7/9/2013, you wrote:
| Quote: | 7/9/2013
Hello Bob Nuckolls,
OC
Thank you. Yeah, I was aware that we'd thrashed some
ACS switch issues here on the List . . . was wondering
if you were aware of problems surfacing in other forums.
I think my reference to the relative 'suckiness' of key
switches was framed in notion that airplanes needed to
emulate automobiles, that the switch is big and expensive,
and that keys offered any great measure of security.
I flew a rental airplane home after having lost the
keys. Wiggled the terminals on the back of the
switch until they broke off, hand propped the airplane
and brought it home. Replaced the terminals when I
got back and replaced the key. Other pilots have
done the lost-key work-around by breaking the termimals
off the back of the mags.
It would have been interesting to do a tear-down on
the problem switch. I'm thinking that it was an
isolated incident and that for the most part the
Off-L-R-B-S key switches perform as advertised.
I just don't think they're an elegant solution to a
simple design problem.
