AVID Mark -4 , Complete Package for sale (Do forward)
miyer2u
PostPosted: Sat Jul 13, 2013 5:58 pm    Post subject: AVID Mark -4 , Complete Package for sale (Do forward) Reply with quote
Kolbers,
This is not Kolb related, but please do forward to those interested...Thanks in advance!)
I am selling my entire package. Details as listed below:
AVID Mark -4 Details: (Built for the Backcountry and pleasure flying It has got everything!)
The airplane is completely covered and painted. The new engine has to be bolted and Instrument panel has to wired and it's ready to go. Installation manual supplied)
Package Price: 17K
Contact: Mahesh Iyer - Cell: 541-613-3329
Aircraft Location: Salt lake City
Completely built airframe with custom built foldable heavy duty Trailer: 10,000 USD
Brand new Rotax 582 in a box with B gear box and electric starter: 6000 USD
(7127 + 300 USD shipping if you purchase from a rotax dealer)
Custom built Bubble doors with Hydraulic Cylinders and gap insulation/Weather proofing: 2500 USD
Additional instruments, Strobes and many others at reduced prices or give away
Brand new Rotax 582 in a box with Carburetor's, Gear Box, Electric starter, Installation CD, Manuals, Rectifier units, Tool kit and rotax registration details: 6000 USD
Firewall forward with complete Aluminum wall, Dyna Engine Mount and floorboard ready to go!
New Dual Brakes with Matco cylinders
New Heavy duty Backcountry GROVE Landing systems
New Tundra tires – 8.00 x 6
Maule Tail wheel
Manuals and Drawings:
Complete original AVID build manual with all drawing's included
Build Pictures in original
POH -Skystar
Engine Includes the following:
Warranty
Rotax tool kit
B gear box
Electric Starter
Rectifier
Oil Injector
Coolant Reservoir
Overflow Reservoir
Dual Bing Carburetor's
Black heat resistant Painted and assembled Exhaust
Exhaust Gaskets
Avid Cowling mounted Dual Radiator Cooling System
Custom Brackets for Installation
Three blade Heavy duty WARP DRIVE prop with Titanium Leading edge and improved
Blade system
Warp drive Protractor for blade adjustment
Aluminum Polished spinner with accessories
Heavy duty powder coated AVID DYNA Engine mount for Rotax 582
Two CHT and two EGT Wasatch Probes
Water /Coolant Temperature Probe
Engine mounting accessories, screws, bolts, nuts included.
RF Suppression capacitor with custom mount
Firewall:
Aluminum Firewall with Heat protector included
Grommets and rubber seal Included
Instruments:
Dash
Altimeter supplied by Avid
Vertical speed indicator supplied by Avid
RPM Indicator
Airspeed
Electronic Elevator Trim
New Ignition/Master Switch
New Circuit Breakers
ELT Emergency locator
ICOM Handheld Radio
Dual Intercom – Flightcomm
Water Temperature
Voltage Indicator
Dual EGT and CHT indicator
Turn Cordinator
Hobbs Indicator
Bubble Doors:
Custom made BUBBLE DOORS for 8-10 Inches of extra space
Brand new Hydraulic pistons for ease of opening bubble doors
Stainless less steel nuts and bolts for mounting
Gap seals
Special drills and rivets for mounting
Complete set of instructions
Prefabricated door frame for COMPLETE view
Painted door frames.
Cowling:
Fully painted and ready to Install AVID Fiber Glass Cowling
Strobes and Nav lights:
Brand new AEROFLASH Strobes and NAV Lights
Extra flashing strobes for Landing gear
PAINTS:
Polyfiber polytone– Bahama Blue
Polyfiber polytone – Lemon yellow
Polyfiber Aerothane for that shiny look
Polyfiber Rejuvenator
Polyspray – Silver
Additional Fabric and tapes
CDROMS:
Avid 4 CD set on build and improvements
Rotax Installation CD
Many Others:
Complete set of Hardware Nuts and Bolts per AVID specs
New Dual Throttle cables
New Fuel Primer set up
Fuel lines
Fuel Selector Valves
Antennas
Avid custom built Round Rudders
Maule Tail wheel assembly
Heavy Hauler Wings
New Floor Panel
New rudder cables and tangs
Custom seats -2
PTT switch
Powder coated body frame
Transportation support bars and cushions
Lead weights in case you are putting a different engine
Decals and Markers
Incabin Heater set up
Two set of seat belts
FAA registered, N numbered
Reason for sale:
I am moving to a 4 seater Cessna as it serves my purpose better.
Mahesh
