yellowbird1
Posted: Sun Jul 07, 2013 7:41 pm Post subject: Fwd: BRS for Xtra |
I'm going to add a BRS to recently acquired Xtra, but I'm not sure which one of the two recommended by the BRS rep to go with. The two sizes are the 1050 and 1350. The l350 is about $1000 more but it will be slower decent. The 1050 is the recommended size on the Kolb web site. So I have a few questions for the Kolb flyers out there.
Is anyone using the 1350 or is everyone using the 1050?
Does anyone have any recommendations of one over the other?
Any suggestions as to where to purchase it other than from the factory and why?
Thanks in advance.
Brad Nation
N952DK
_________________ Brad Nation,
Albuquerque, NM
MK3 Xtra |
rickofudall
Posted: Mon Jul 08, 2013 3:22 am Post subject: Fwd: BRS for Xtra |
Brad, The 1350 is overkill. Once you pull that handle you're just along for the ride anyway, and the Kolb structure will provide great protection.Buy from Kolb and support those who support you.
Rick Girard
On Sun, Jul 7, 2013 at 10:40 PM, Brad Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)> wrote:
| Quote: | --> Kolb-List message posted by: Brad Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)>
Thanks in advance.
Brad Nation
N952DK
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rowedenny
Posted: Mon Jul 08, 2013 4:48 am Post subject: Fwd: BRS for Xtra |
Very good advice for all of us Kolb owners, we have to keep the Boys in London in business, I think I'll check and see what kind of hats and tee shirts they have for sale these days, keep spreading the gospel of Homer and support Brian and Travis!
Dennis "Skid" RoweMk3, 690L-70, Leechburg, PA
[quote]Buy from Kolb and support those who support you.
Rick Girard
colin.scott.hudson(at)gma Guest
Posted: Tue Jul 09, 2013 5:52 pm Post subject: Fwd: BRS for Xtra |
I talked with the Reps at BRS on that subject prior to making my purchase. I asked for their opinion on the matter. I was told that they put a rather large margin of safety in their chutes and they said the 1050 would more than safely carry me down at max gross weight. Not sure what engine you have on your X-tra. I am running the Jabiru 2200 and did have a problem. At first I installed the BRS Model VLS. It disrupted the airflow into my cylinders and my CHT went out of sight. The BRS folks recommend that I try the 1050 canister model and it worked perfectly. It set right in the middle and the air flowed right around it into the cylinders. I will also add that the folks at BRS were great to work with during this crisis. You will have to modify your center section plexi-glass to slid around the BRS cable, but it's not too difficult. I can provide photos if you get serious.
Colin
Colin Hudson
Retired Army
10,000+
N424AL
M3 X-tra
[quote] --> Kolb-List message posted by: Brad Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)>
Thanks in advance.
Brad Nation
N952DK
le, List Admin.
yellowbird1
Posted: Tue Jul 09, 2013 7:38 pm Post subject: Fwd: BRS for Xtra |
All,
Thanks for the input. I talked to Travis at Kolb about the various systems and ended up buying a 1050 VLS from him which shouldn't be a problem with the 912.. It should be here in a few weeks.
Colin: photos would be great, thanks for the offer.
Brad
On Jul 9, 2013, at 19:52, Colin Hudson <colin.scott.hudson(at)gmail.com (colin.scott.hudson(at)gmail.com)> wrote:
[quote]I talked with the Reps at BRS on that subject prior to making my purchase. I asked for their opinion on the matter. I was told that they put a rather large margin of safety in their chutes and they said the 1050 would more than safely carry me down at max gross weight. Not sure what engine you have on your X-tra. I am running the Jabiru 2200 and did have a problem. At first I installed the BRS Model VLS. It disrupted the airflow into my cylinders and my CHT went out of sight. The BRS folks recommend that I try the 1050 canister model and it worked perfectly. It set right in the middle and the air flowed right around it into the cylinders. I will also add that the folks at BRS were great to work with during this crisis. You will have to modify your center section plexi-glass to slid around the BRS cable, but it's not too difficult. I can provide photos if you get serious.
Colin
Colin Hudson
Retired Army
10,000+
N424AL
M3 X-tra
Thanks in advance.
Brad Nation
N952DK
le, List Admin.
://www.matronics.com/Navigator?Kolb-List
cs.com
matronics.com/contribution
Albuquerque, NM
MK3 Xtra |
