Drilling Center Of Tube
Dnul
PostPosted: Thu Jul 11, 2013 10:36 am    Post subject: Drilling Center Of Tube Reply with quote
To drill the center of a tube use a "V" block. Simply lower the drill on the drill press down to the bottom of the "V" to position for center.
Dnul
Carolina Flyer
PostPosted: Thu Jul 11, 2013 1:12 pm    Post subject: Re: Drilling Center Of Tube Reply with quote
Here is what I use and it works perfect every time
 Filesize:  193.78 KB
 Viewed:  6824 Time(s)
 Filesize:  88.89 KB
Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
View user's profile Send private message Yahoo Messenger
Dnul
PostPosted: Fri Jul 12, 2013 10:22 am    Post subject: Re: Drilling Center Of Tube Reply with quote
That would be great to order for drilling the vertical stabilizer post, the drag strut, or the landing gear leg and the universal joint on the aileron control tube which would be drilled inaccurately. It might be used to drill an innumerable number of holes in small tubing used in the wing.
Dnul
Dnul
PostPosted: Fri Jul 12, 2013 10:26 am    Post subject: Re: Drilling Center Of Tube Reply with quote
http://www.skygeek.com/eastern-edf1-drill-rite.html sells the drill guide.
Dnul
