rv10rob(at)gmail.com Guest
Posted: Tue Jul 09, 2013 1:32 pm Post subject: Blocking heater vent outlets |
My rear heater leaks--the door is bent, so even when it's closed, it still lets a decent amount of hot air through. As a temporary fix, does anyone see a problem with using aluminum tape to block the air outlets, by the rear passenger feet? I figure there will be no air flow, so no issue. Thanks...
-Rob
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
arplnplt(at)gmail.com Guest
Posted: Tue Jul 09, 2013 5:57 pm Post subject: Blocking heater vent outlets |
Block the inlet in the engine compartment.
Dave Leikam
On Jul 9, 2013, at 4:32 PM, Rob Kochman wrote:
[quote]My rear heater leaks--the door is bent, so even when it's closed, it still lets a decent amount of hot air through. As a temporary fix, does anyone see a problem with using aluminum tape to block the air outlets, by the rear passenger feet? I figure there will be no air flow, so no issue. Thanks...
-Rob
Rob Kochman
Woodinville, WA
Posted: Wed Jul 10, 2013 4:48 am Post subject: Blocking heater vent outlets |
I agree. Otherwise all of that hot air is sitting inside the scat tube inside the tunnel. Another option, temporarily, would be to block off the fresh air inlet on the baffles that goes to the rear seat heater.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Jul 9, 2013, at 9:57 PM, David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)> wrote:
[quote]Block the inlet in the engine compartment.
Dave Leikam
| Quote: | My rear heater leaks--the door is bent, so even when it's closed, it still lets a decent amount of hot air through. As a temporary fix, does anyone see a problem with using aluminum tape to block the air outlets, by the rear passenger feet? I figure there will be no air flow, so no issue. Thanks...
-Rob
Rob Kochman
Woodinville, WA
Posted: Wed Jul 10, 2013 5:47 am Post subject: Blocking heater vent outlets |
I fly in FL and my Traumahawk had the same problem .... so I pulled the scat tube off the muffler and placed it in the bottom cowl so I got a little suction on it ..... didn't want the smells in the cockpit. When winter rolls around .... all 4 days of it .... I just slip the scat tube back in place.
I plan on regulating the amount of heat in the cabin of the -10 by blocking off some of the inlet on the baffling with metal tape ..... when I get flying. I think about 1/2 of the diam should be a good start.
Linn
On 7/10/2013 8:48 AM, Jesse Saint wrote:
[quote] I agree. Otherwise all of that hot air is sitting inside the scat tube inside the tunnel. Another option, temporarily, would be to block off the fresh air inlet on the baffles that goes to the rear seat heater.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
flysrv10(at)gmail.com Guest
Posted: Wed Jul 10, 2013 6:15 am Post subject: Blocking heater vent outlets |
I fly in Florida too and have routed one of the scat tubing with fresh air from the cool side of the cowl, in the high pressure area, into the tunnel. The tunnel stays fairly cool (although warm to touch in the summer) and I have flown in 20 deg weather without suffering from the cold. At these temperatures, if the wife is in the back, she sez it is a little chilly and sleeps with a blanket. No different flying the airlines these days. During decent, it gets chilly in the front too but not cold.
Do Not archive.
On Jul 10, 2013, at 9:46 AM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote] I fly in FL and my Traumahawk had the same problem .... so I pulled the scat tube off the muffler and placed it in the bottom cowl so I got a little suction on it ..... didn't want the smells in the cockpit. When winter rolls around .... all 4 days of it .... I just slip the scat tube back in place.
Linn
| Quote: | I agree. Otherwise all of that hot air is sitting inside the scat tube inside the tunnel. Another option, temporarily, would be to block off the fresh air inlet on the baffles that goes to the rear seat heater.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Posted: Wed Jul 10, 2013 2:33 pm Post subject: Blocking heater vent outlets |
Thanks, guys... I should have specified that "temporary" meant very temporary--until I pull the cowl next time. My thought is that since the outlet is blocked, there's no airflow, and thus the scat tube isn't really heating up.
I've been told *not* to block the inlet at the baffles, since it's required to cool the shrouded portion of the exhaust.
-Rob
On Wed, Jul 10, 2013 at 7:15 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
| Quote: | I fly in Florida too and have routed one of the scat tubing with fresh air from the cool side of the cowl, in the high pressure area, into the tunnel. The tunnel stays fairly cool (although warm to touch in the summer) and I have flown in 20 deg weather without suffering from the cold. At these temperatures, if the wife is in the back, she sez it is a little chilly and sleeps with a blanket. No different flying the airlines these days. During decent, it gets chilly in the front too but not cold.
Do Not archive.
| Quote: | I fly in FL and my Traumahawk had the same problem .... so I pulled the scat tube off the muffler and placed it in the bottom cowl so I got a little suction on it ..... didn't want the smells in the cockpit. When winter rolls around .... all 4 days of it .... I just slip the scat tube back in place.
Linn
Jesse Saint
C: [url=tel:352-427-0285]352-427-0285[/url]
F: [url=tel:815-377-3694]815-377-3694[/url]
ass="im">
Rob Kochman
Woodinville, WA
Posted: Wed Jul 10, 2013 3:49 pm Post subject: Blocking heater vent outlets |
I believe you are right. I don't remember how I managed mine. If you need to know, I can look and let you know.
Do not archive.
Rob Kermanj
On Jul 10, 2013, at 6:33 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]Thanks, guys... I should have specified that "temporary" meant very temporary--until I pull the cowl next time. My thought is that since the outlet is blocked, there's no airflow, and thus the scat tube isn't really heating up.
-Rob
Do Not archive.
Linn
Jesse Saint
ass="im">
Rob Kochman
Woodinville, WA
