frank goodnight
Posted: Tue Jul 09, 2013 4:55 am Post subject: 912 propeller, 4" prop hub ext, Exhaust for sale |
Can you send a larger clearer picture ? I can't see if i can use it from this pic.
Frank
Sent: Monday, July 8, 2013 8:21 PM
Subject: 912 propeller, 4" prop hub ext, Exhaust for sale
--> Kolb-List message posted by: "Jason Omelchuck" <jason(at)trek-tech.com (jason(at)trek-tech.com)>
Hello All,
For the 912 engine I have:
A 68" 3 bladed taper tip Warp Drive propeller with nickel leading edge $400
A 4" propeller hub extension $100
A Stainless steel exhaust system (at least I think it is stainless as a magnet just barely sticks to it) $150 Attached is a picture of the exhaust configuration.
All are in great condition and buyer pays for shipping.
Jason Omelchuck
http://forums.matronics.com/viewtopic.php?p=404244#404244
http://forums.matronics.com//files/exhaust_167.png
Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Tue Jul 09, 2013 6:28 am Post subject: Re: 912 propeller, 4 |
Hello Frank,
I will search for a better picture but the exhaust has been pulled off of the aircraft already. The exhaust can is nestled under the gearbox with the exhaust pipe exiting downward on the right side. The cylinders closest to the gearbox have a very short header before it enters the exhaust can, the cylinders farthest away from the gear box have the header curve back around under the cylinders and go back to the can. There are welded in bosses for EGT's in all 4 headers. The exhaust will only have enough prop clearance if you are using a prop hub extension. The set up would work very well on any Kolb using a 912 engine and you would not have the added clutter on top of the engine.
Best Wishes
Jason
russk50(at)gmail.com Guest
Posted: Fri Jul 12, 2013 5:13 am Post subject: 912 propeller, 4" prop hub ext, Exhaust for sale |
JasonDid you have a cowling on the 912? Loox like some mounting tabs in the pic. What aircraft?
On Jul 9, 2013, at 8:54 AM, frank goodnight wrote:
[quote]Can you send a larger clearer picture ? I can't see if i can use it from this pic.
Frank
From: Jason Omelchuck <jason(at)trek-tech.com (jason(at)trek-tech.com)>
Hello All,
Jason Omelchuck
Jason Omelchuck
Posted: Sat Jul 13, 2013 1:41 pm Post subject: Re: 912 propeller, 4 |
Yes the airplane had a cowling, it was an Aeroprakt A20. I still have a 300 hour Rotax 912ULS for sale that is perfect for a Kolb. It would come with everything needed to make it work on a Kolb. Engine, prop hub extender, 3 bladed 68" warp drive propeller, exhaust, radiator, oil cooler, oil tank, Grand Rapids EIS. The whole works can be had for 13K plus shipping.
Jason
