Battery capacity tester- Why isn't there a flyback diode?
PostPosted: Fri Jul 19, 2013 9:00 am    Post subject: Battery capacity tester- Why isn't there a flyback diode? Reply with quote
At 09:32 AM 7/19/2013, you wrote:
<mrspudandcompany(at)verizon.net>
Yes, a coil spike suppressor would e good idea.
Should have been there in the first place . . . sorry
'bout that.
Actually I've been searching the antique shops for an AC plug-in
clock and haven't been able to find one.
Walmart has a couple of these clocks in the $10 range.
I bought one at my local store recently.
But they are getting harder to find. The AA powered
quartz movement has all but totally captured the
wall/desk clock market.
The cap-tester I photographed last week measures
both battery voltage and elapsed time in software.
PostPosted: Sat Jul 20, 2013 7:56 am    Post subject: Re: Battery capacity tester- Why isn't there a flyback di Reply with quote
A quartz clock with hands can be used instead of an AC powered clock. Strip the ends of two wires. Flatten the ends with a hammer and anvil. Make a sandwich of the two flattened wires with a paper or plastic insulator between them. Place this sandwich in the clock battery holder between the AA battery and a holder contact. Connect the other ends of the two wires to the tester relay.
Joe
Joe Gores
