rowlandcarson(at)gmail.co Guest
Posted: Sun Jul 21, 2013 1:09 pm Post subject: andair gascolator query |
I've got an Andair GAS375-M gascolator that I plan to fit in the same compartment as the electric fuel pump. Obviously it is desirable to have it mounted with the bottom near the bottom skin of the fuselage so that the drain can be easily activated. However, it's necessary also to have room to remove the bowl. That means cutting an access hole in the bottom skin. Has anyone already got a LAA mod number that includes that sort of thing?
I suppose (plan B) it would also be possible to mount the gascolator sufficiently high that the bowl could be removed from inside the aircraft, but that would mean the drain would be a long way from the fuselage floor and so not easy to operate from outside. Maybe it could also be operated from inside if the sample cup is small enough?
Any thoughts?
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
rparigoris
Posted: Sun Jul 21, 2013 2:43 pm Post subject: andair gascolator query |
Hi Rowland
In USA, not LAA approved but here is what I did with my two 375s on my monowheel with 914:
http://www.europaowners.org/main.php?g2_itemId=28612
Drain and service from outside the aeroplane.
NOTE: When fooling with my fuel system on the bench, it is a really bad thing to have a leak in either the drain or bowl O ring of the 375. If you are having a hard time putting the bowl back on, install a new O ring as the old one probably changed dimension (keep some on hand). Another caution, when unscrewing the filter, do not turn from the side opposite where the threads are, it can damage the filter. I inspected my filter inside, and low and behold there was build crud from Andair stuck just about holding onto the adhesive they used during assembly just waiting to get to my carbs. Andair replaced free of charge, good idea to have a very good look inside.
Ron Parigoris
stranfaer(at)btinternet.c Guest
Posted: Mon Jul 22, 2013 1:00 am Post subject: andair gascolator query |
Rowland
Speak to Graham Singleton he has a mod and plans for how to do this, I am also in the process of doing with the addition of putting in aluminium lines to the bulkhead .
rgds
David
The other one
Sent to you from David Joyce
www.eastmidsspas.com
To: Europa e-mail list list <europa-list(at)matronics.com>
Sent: Sunday, 21 July 2013, 22:09
Subject: andair gascolator query
--> Europa-List message posted by: Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)>
Any thoughts?
in friendship
Rowland
| <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> http://www.rowlandcarson.org.uk/
| pictures: http://w.com/" = --> [quote][b]
mau11(at)free.fr Guest
Posted: Mon Jul 22, 2013 1:17 am Post subject: andair gascolator query |
On 22/07/2013 10:59, DAVID JOYCE wrote:
Rowland
rgds
David
The other one
From: Rowland Carson <rowlandcarson(at)gmail.com> (rowlandcarson(at)gmail.com)
To: Europa e-mail list list <europa-list(at)matronics.com> (europa-list(at)matronics.com)
Any thoughts?
in friendship
Rowland
| Hi David I am interested to install aluminium fuel circuit in my monowheel.
Where do you buy components, tube and connectors ?
Posted: Mon Jul 22, 2013 1:21 am Post subject: andair gascolator query |
Rowland
rgds
David
The other one
Any thoughts?
in friendship
Rowland
| Hi David my message is started too quick§
For the aluminium tube it is necessary annealed aluminum tube. To fold the tube easily.
Many Thanks
Michel AUVRAY
Posted: Mon Jul 22, 2013 1:22 am Post subject: andair gascolator query |
Rowland
rgds
David
The other one
Any thoughts?
in friendship
Rowland
| Hi David, my message is started too quick!
For the tube it is necessary annealed aluminum tube. To fold the tube easily.
Many Thanks
Michel AUVRAY
Posted: Mon Jul 22, 2013 2:51 am Post subject: andair gascolator query |
Rowland
You could try Mod number 10823, issue 2, which is Colin Smallwood's installation. (tri gear)
There are a lot of Europas with similar mods but none really identical, depends where you start from,
ideally with the cockpit module on the bench.
Use plan A, cut a D shaped biscuit from the bottom, add a hinge and one of the clips used for the cowling access panels. I cut the biscuits out with a Stanley knife or a hacksaw blade ground thin.
Then flox in the edges.
Graham
Any thoughts?
in friendship
Rowland
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Mon Jul 22, 2013 3:09 am Post subject: andair gascolator query |
Rowland
The mod I sent you incorporates a forward bulkhead and a removable panel
where the Mono wheel would normally be. I mounted the gascolator about 200mm
forward of the fuel selector on the inside of the now disused mono wheel bay
low down so the its drain could be accessed easily and assumed I would
remove the outer floor panel to service the gascolator. I mounted the
electric fuel pump on the forward bulk head and piped the output up and out
of the top of the centre section under the instrument module and across to
the far side of the starboard foot well top corner.
Posted: Mon Jul 22, 2013 3:31 am Post subject: andair gascolator query |
On 22 Jul 2013, at 12:09, richard wrote:
Rowland
The mod I sent you incorporates a forward bulkhead and a removable panel where the Mono wheel would normally be
Richard - thanks, but the monowheel is occupying the space it normally occupies in my machine! I think Graham Singleton's advice about cutting an access panel is probably easiest to follow. It seems there is no technical issue with cutting a hole in the bottom of the aeroplane .... but no doubt one will have to get a "letter of no technical objection" from whoever is empowered to sign such things now at Europa.
Thanks for all the suggestions.
in friendship
Rowland
budyerly(at)msn.com Guest
Posted: Tue Jul 23, 2013 8:41 am Post subject: andair gascolator query |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Rowland,
Although I am not a fan of the gascolator in a Europa, I prefer the Andair. You are so right in wanting to place it as low as possible. Few gascolators work well elevated in the fuselage (the trap function is thwarted) and the unit seal must be 100% as any small leak will cause the pump to loose prime when the fuel is pulled through them. I would have no problem with mounting it under the fuselage with the bowl out in the air and fabricating an aerodynamic fairing to cover it. The cover would need a hole in the bottom for quick draining. One quick turn fastener on the front and back and the whole cover would come off and the device would be serviceable. A desireable but very cramped area would be in the center under the pitch tube and between the tanks. If you make the hole a half inch larger than the bowl it should allow service work. Access holes don't scare me as you must just take the time to put the structure back into the fuselage. Easy to do under construction, but messy with a completed aircraft.
Bud Yerly
davidjoyce(at)doctors.org Guest
Posted: Wed Jul 24, 2013 12:36 am Post subject: andair gascolator query |
Rowland, I have an Andair minigascolator behind the tanks
accessed thru a flap and with a drain tap in its bottom,
approved by LAA and very serviceable. Regards David Joyce
GXSDJ
On Tue, 23 Jul 2013 12:40:56 -0400
"Bud Yerly" <budyerly(at)msn.com> wrotek
[quote] Rowland,
Bud Yerly
Posted: Wed Jul 24, 2013 3:02 pm Post subject: andair gascolator query |
Rowland,
I put mine under the baggage bay with a small door for access. If you airplane is closed up then this will be a bit of a pain to install.
I know that this is taking the thread a bit off topic, and you are LAA constrained but if I was to do it over again I would install two, one in the main line and one in the reserve to remove a single point of failure. I have not ever seen enough debris in mine to cause a problem but I recall Alex Bowman (?) landing out because fine rust passed though his funnel strainer but clogged his gascolator. Not sure if it was an Andair
I with Bud when it comes to Andairs, they are the "gold standard" and the new filter element has a much larger area than the original. It would take a lot of crud to block it.
Regards, Paul
On Tue, Jul 23, 2013 at 11:40 AM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote] Rowland,
Bud Yerly
