bobnoffs
Joined: 04 Jul 2012 Posts: 135 Location: northern wi.
Posted: Sat Jul 20, 2013 10:02 am Post subject: jumpimg gauge needles |
i know this has come up before but i can't find it. a friend with a 912 has the needles on his falcon engine gauges jumping and twitching while engine is running. are there places to look at to fix this? he has been told to run wire from regulator to battery terminal, not just to bus. anything else come to mind?
bob noffs
Posted: Sat Jul 20, 2013 12:06 pm Post subject: jumpimg gauge needles |
At 01:01 PM 7/20/2013, you wrote:
| Quote: | i know this has come up before but i can't find it. a friend with a
Does the jumping stop with the alternator
OFF?
Can you describe the architecture of his
ground system? Do all the gauges wiggle
or just some . . . and what do they display.
Are there oil, coolant or fuel SENSORS
that ground locally . . . in others words
ground where they mount and then carry their
data off on a single wire?
bobnoffs
Posted: Sat Jul 20, 2013 1:15 pm Post subject: jumpimg gauge needles |
bob, i know the answer to some of your questions but i will track down arnie and get answers for them all and get back to you.
bob noffs
On Sat, Jul 20, 2013 at 3:05 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | i know this has come up before but i can't find it. a friend with a 912 has the needles on his falcon engine gauges jumping and twitching while engine is running. are there places to look at to fix this? he has been told to run wire from regulator to battery terminal, not just to bus. anything else come to mind?
OFF?
_ities such as List Un/Subscription,
www.matronics.com/Navigator?AeroElectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
======================ttp://forums.matronics.com/" target="_blank">http://forums.matronics.com
====================== -Matt Dralle, List Admin.
bobnoffs
Posted: Sun Jul 21, 2013 6:48 am Post subject: jumpimg gauge needles |
hi bob,
ok, got the info. mitchell gauge for water temp., oil temp and oil pressure. these 3 gauges all twitch, water temp. the worst. the electric uma tach and the elec. vdo fuel gauge work fine. all gauges have a separate ground wire back to a a common ground.
bob noffs
On Sat, Jul 20, 2013 at 4:15 PM, bob noffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
[quote] bob, i know the answer to some of your questions but i will track down arnie and get answers for them all and get back to you.
bob noffs
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
OFF?
======================s List Un/Subscription,
Posted: Sun Jul 21, 2013 12:04 pm Post subject: jumpimg gauge needles |
At 09:47 AM 7/21/2013, you wrote:
| Quote: | hi bob,
Okay, a picture is beginning to emerge. I suspect
those first three have single wires to the guages
and they ground through their threaded fittings
to the engine.
My working theory is that there is substantial
resistance between the crankcase and the "common
ground." I.e. the common ground is NOT a forest-
of-tabs on the firewall with a nice bond strap
between crankcase and forest-of-tabs.
The EASY fix is to take GAUGE grounds for the
3 twitchy instruments out to the crankcase. I'm
90% certain that the observed twitchiness will
go away.
Years ago I think I related a story about a Long-Ez
driver who had a 30A alternator on the engine but
no starter. His VERY long crankcase ground routed
to battery(-) in the nose offered substantial
voltage drop when the alternator was charging.
This cause a rather large excursion in his gauges
with local ground sensors when the alternator
was turned ON and OFF.
Bringing instrument grounds for those systems
back to the crankcase DIDN'T change the voltage
drop on the alternator ground wire, it just moved
that drop OUTSIDE the signal loop for the gauge.
