Posted: Sun Jul 21, 2013 5:01 pm Post subject: Garmin 496 with Trutrak Autopilot, Dynon EFIS D100 and Gar |
At 03:23 PM 7/21/2013, you wrote:
| Quote: | Folks,
Someone must have done this, but I can’t find any references. The Garmin 496 can provide directional reference to the Pictorial Pilot Directional AP, position and direction to the EFIS HSI display, and VOR and COM frequencies to the SL30 NAV/COMM. - It seems all devices can work with 9600 baud.
- The SL30 and D100 are OK with the 496 “Data out� setting “NMEA & VHF out.� The AP documentation doesn’t mention the VHF angle.
- The EFIS and AP can live with the 496 “Advanced� setting “Normal.� I don’t know about the SL30 but doubt it matters.
Do I simply split the 496 “data out� wire three ways and run to each device and hope the AP isn’t confused by the extraneous commands from the GPS intended for the SL30?
Any recommendations on running grounds between the devices, using screened cable etc.? |
NEMA data streams are fixed format, labeled sentences
of ordered data words. There are few devices that read
all the data from any given device. Listeners watch all
data strings starting with the right label, and then they
disassemble the sentence for the data of interest.
For example, if your listener wants to know lat,lon it looks
for a sentence formatted to carry that data. Like "GGA"
GGA - essential fix data which provide 3D location and accuracy data.
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
Where:
GGA Global
Positioning System Fix Data
123519 Fix
taken at 12:35:19 UTC
4807.038,N Latitude 48 deg 07.038'
N
01131.000,E Longitude 11 deg 31.000' E
1 Fix
quality: 0 = invalid
1 = GPS fix (SPS)
2 = DGPS fix
3 = PPS fix
4 = Real Time Kinematic
5 = Float RTK
6 = estimated (dead reckoning) (2.3 feature)
7 = Manual input mode
8 = Simulation mode
08 Number of
satellites being tracked
0.9 Horizontal
dilution of position
545.4,M Altitude,
Meters, above mean sea level
46.9,M
Height of geoid (mean sea level) above WGS84
ellipsoid
(empty field) time in seconds since last DGPS
update
(empty field) DGPS station ID number
*47 the checksum
data, always begins with *
| In this case, the listener watches for $GPGGA to come along
then it parses the sentence for the second and third words
after the header.
There are proprietary sentences too. For example, Garmin
may find it useful to output a $PGRME sentence where word
pairs offer position error distances and units in which
those data are given.
[b]GarminThe following are Garmin proprietary sentences. "P" denotes proprietary, "GRM" is Garmin's manufacturer code, and "M" or "Z" indicates the specific sentence type. Note that the PGRME sentence is not set if the output is set to NMEA 1.5 mode.
| Quote: | $PGRME,15.0,M,45.0,M,25.0,M*1C
where:
15.0,M
Estimated horizontal position error in meters (HPE)
45.0,M
Estimated vertical error (VPE) in meters
25.0,M
Overall spherical equivalent position error
| So it's conceivable that your constellation of listeners
are interested in only a small port of all data offered by
the talker.
So as long as your 'talker' offers all the data needed
by all of your 'listeners', then each listener will sift
the good stuff out of the noise. Hook them all together.
Twisted pairs are good data lines. 9600 Baud is not
a bit EMC risk but shielding the wires is not a bad
idea. Ground the shield at listener end only.
Bob . . . [quote][b]
Posted: Sun Jul 21, 2013 6:32 pm Post subject: Garmin 496 with Trutrak Autopilot, Dynon EFIS D100 and Gar |
Bob and I differ on where to terminate the screen, but that drills
into some serious minutiae on this project. It's probably just not
necessary at all. (Bob -- I wouldn't mind hearing your thoughts on
the termination location rationale though)
Sure . . . easy . . . flip a coin.
Shielding is a prophylactic against the weakest of all
EMI propagation modes - electrostatic.
Modern serial data signals will deliberately soften
the leading and trailing edges of the data to minimize
the strength of the propagation mode in bundles.
Twisting pairs of a balanced data stream (Like RS422)
drops the coupling mode to a small fraction of and
already weak coupling mode.
Twisting an unbalanced data stream can't exploit
the common mode rejection capability of a balanced
pair receiver . . . but it still reduces electrostatic
coupling by a substantial proportion.
Shielding breaks the electrostatic propagation mode.
The currents flowing in the shield are so tiny as to be
difficult to measure . . . one can terminate the shield
at ANY low impedance node tied to signal or power ground and it's
got all the conductivity needed to do its nearly
insignificant job.
Grounding shields at the listener-end is a convention
we used most places I worked . . . a convention not
driven by significant physics.
