rparigoris
Posted: Thu Jul 25, 2013 10:55 pm Post subject: Flap pushrod hits pitch pushrod |
Hi Group
We're in the process of installing the flap control on our XS Monowheel.
We needed to tweak (bend) the pushrod a little to get it to clear the rear liftpin tierod and pitch cross tube.
Things are looking about as good as they are going to get.
When gear is up or down when the flap pushrod is at rest (1 positive G), the rod is resting on the aft most right side of the tunnel.
The thing I'm not crazy about, if I push the flap pushrod port, which would represent negative G's (bouncing on the ground), it can rub on the pitch pushrod, or the head of the front attachment bolt for the pitch pushrod.
Have those flying just ignored this, or put some sort of wear block/guide to keep it from the pitch pushrod?
Details most welcomed.
Thx.
Sincerely
Ron Parigoris
Fred Klein
Posted: Fri Jul 26, 2013 5:53 am Post subject: Flap pushrod hits pitch pushrod |
On Jul 25, 2013, at 11:55 PM, rparigoris wrote:
| Quote: | | We needed to tweak (bend) the pushrod a little to get it to clear the rear liftpin tierod and pitch cross tube. |
Ron...I don't recall having any interference between these components...Fred
Posted: Fri Jul 26, 2013 1:02 pm Post subject: Flap pushrod hits pitch pushrod |
Ron, mine does the same. I wrapped it with nylon spiral wrap that is used for cables. Its seems to do a nice job of protecting things.
Paul
On Fri, Jul 26, 2013 at 1:55 AM, rparigoris <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)> wrote:
[quote] --> Europa-List message posted by: "rparigoris" <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)>
Hi Group
Thx.
Sincerely
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=405324#405324
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
