kheindl(at)msn.com Guest
Posted: Tue Jul 30, 2013 4:24 am Post subject: oil change with oil thermostat |
After installation of the oil thermostat and new cooler I am about to put in the oil. It just occurred to me that the thermostat will block the cold oil from circulating. Should I pre-heat the oil, or what is the recommended technique ?Any good ideas much appreciated.
Karl
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Tue Jul 30, 2013 5:02 am Post subject: oil change with oil thermostat |
Hi Karl. The oil thermostat will always have a bypass function so there is no possibility of starving the engine of oil when cold. I have one fitted and it works very well.
Do remember to re-prime the oil system as per the Rotax manual i.e. remove one set of plugs and turn the engine over on the starter motor until you get oil pressure .
Regards Richard
Sent: Tuesday, July 30, 2013 1:23 PM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: oil change with oil thermostat
After installation of the oil thermostat and new cooler I am about to put in the oil. It just occurred to me that the thermostat will block the cold oil from circulating. Should I pre-heat the oil, or what is the recommended technique ? Any good ideas much appreciated.
Karl
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Tue Jul 30, 2013 6:06 am Post subject: oil change with oil thermostat |
thank you very much Richard, that's a relief. i will watch the rotax video again, and also apply pressure into the oil container via the vent.Karl
Subject: Re: oil change with oil thermostat
Date: Tue, 30 Jul 2013 14:01:38 +0100
Regards Richard
Karl
target="_blank">http://www.matronics.com/Navigator?Europa-List
