soldering coax
messydeer
PostPosted: Sun Aug 04, 2013 2:37 pm    Post subject: soldering coax Reply with quote
Hi!
I'm installing a transponder in my Sonex. A couple years ago, I bought a 9-30-10 TED 90 degree coax adapter fitting, shown in the attached pic. What are the C ring and small cylindrical shaped items for? Any instructions for soldering this?
Dan
 Filesize:  5.9 KB
 Viewed:  6224 Time(s)
Dan
Bob McC
PostPosted: Sun Aug 04, 2013 3:57 pm    Post subject: soldering coax Reply with quote
Try this from Bob's site.
http://tinyurl.com/pqvb263
Bob McC
[quote] --
Bob McC
Falco #908
(just starting)
Bob McC
PostPosted: Sun Aug 04, 2013 4:03 pm    Post subject: soldering coax Reply with quote
The circlip and washer are to secure the connector into a panel using the
groove around its "nose". The cylindrical sleeve is to adapt the connector
to different diameters of coax. (link to instructions sent separately)
Bob McC
[quote] --
Bob McC
Falco #908
(just starting)
messydeer
PostPosted: Sun Aug 04, 2013 7:17 pm    Post subject: Re: soldering coax Reply with quote
Ah!!
A picture is worth a thousand words. I'm guessing I won't need that barrel adapter, but I'll find out when I put things together.
Dan
Dan
