Posted: Sat Jul 27, 2013 2:53 am Post subject: 14V or 28V |
Guys
I suppose this has been discussed before, but my laziness to search in the
archives makes me raise this issue again.
In the RV-10 that I am building, I am thinking in using a 12V(14V)
electrical system, most probably based in the Nuckolls's Z-14 architecture,
with the VP-X Pro box.
However, when searching for the Comm radios to choose from, I found that the
best radios, in terms of transmitting power (16W), are 28V.
Should I consider changing all the electric system to 28V, or is it possible
to have a 14V system and include a 14/28 voltage "converter" to feed the
radio?
All opinions welcome
Carlos
mrspudandcompany(at)veriz Guest
Posted: Sat Jul 27, 2013 5:55 am Post subject: 14V or 28V |
| Quote: | In the RV-10 that I am building, I am thinking in using a 12V(14V)
architecture,
the
possible
radio?
28 volt systems have become the normal for many new production
aircraft. You can use lighter fat wires and thus save a bit of
weight.
All of the electrical components are available in either voltage.
I would recommend that you go with one voltage or the other, and not
try to
run a dual voltage machine. Just keep in mind that if you go with a
28 volt
system, you must keep all other electrical items such as, starter,
lighting,
contactors and anything else plugged into the system, compatable
with the
28 volts.
Roger
ceengland7(at)gmail.com Guest
Posted: Sat Jul 27, 2013 5:56 am Post subject: 14V or 28V |
On 07/27/2013 05:49 AM, Carlos Trigo wrote:
Guys
radio?
Carlos
Unless you're operating in an environment where the last 1/2 mile of
range matters, don't worry about it. VHF is basically line of site, &
even a 3W handheld (with a proper external antenna) can reach the
horizon unless you're flying at airliner altitudes. I'm too lazy to dig
up the math, but here's a rough rule of thumb: If you want to double
your range, multiply power by 10.
Charlie
bbradburry(at)bellsouth.n Guest
Posted: Sat Jul 27, 2013 6:35 am Post subject: 14V or 28V |
In an experimental plane, you will save a few ounces, maybe even a pound or
two in smaller wires, but you will add 10-15 pounds for the larger battery.
If you decide you should install two batteries...WOW! You will not find any
automotive parts that are 28V. I suggest you will need a reason better than
weight savings to go 28V.
B2
donjohnston
Posted: Sat Jul 27, 2013 2:16 pm Post subject: Re: 14V or 28V |
| bbradburry(at)bellsouth.n wrote: | In an experimental plane, you will save a few ounces, maybe even a pound or
weight savings to go 28V.-- |
I would agree. I'm building a 28v system and the... adjustments I've had to make are a bit of a pain. If I were starting from scratch, I'd probably go with a 14v system.
henador_titzoff(at)yahoo. Guest
Posted: Sat Jul 27, 2013 5:31 pm Post subject: 14V or 28V |
Don, Bill, Carlos,
Apart from the 14V vs. 28V debate, I'd like to point out that one doesn't necessarily have to add 10-15 lbs for the "28V" battery, i.e. it isn't necessarily that much of a "larger" battery. 12V batteries have six plates, while "28V" batteries have 12 plates. If one needs the same amount of power at the starter, an equally sized "28V" battery with smaller plates will do the job, since P = E*I. Voltage goes up, but current goes down in the same proportion, or slightly less since the voltage drops to the starter will sum less. In summary, same battery size, same energy density, just higher voltage with less current needed.
Enough theory, now let's look at real world numbers. I've put quotes around the 28Vs above, because 28V aircraft batteries are actually 24V, as one can see at the following link:
http://www.concordebattery.com/allaircraftbatteries.php
Note that the Concorde CB-25 12V battery weighs 22 lbs, while the CB24-11 24V battery weighs 27 lbs. If Carlos plans his electrical system well, surely he can make up that additional 5 lb weight by using fat wires.
Henador Titzoff
Sent: Saturday, July 27, 2013 6:16 PM
Subject: Re: 14V or 28V
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
| Quote: | In an experimental plane, you will save a few ounces, maybe even a pound or
http://forums.matronics.com/viewnbsp; --> http://www.matronics.com/Navigator?AeroElectric-List<; http://forums.sp; - List Contribution Web Site -
_; -Matt Dralle, List =========
Posted: Sat Jul 27, 2013 7:27 pm Post subject: 14V or 28V |
At 09:34 AM 7/27/2013, you wrote:
<bbradburry(at)bellsouth.net>
not strictly true. When going to a higher voltage system
a battery with 1/2 the a.h. capacity has the same stored
energy as the lower voltage battery.
| Quote: | If you decide you should install two batteries...WOW! You will not find any
The weight savings are pretty small . . . we did
some calculations on it way back when here on the
list. Not very impressive until you considered
a sea-plane with very long + and ground leads.
Many of the compelling reasons for 28v circulating
in the wild are more fantasy or error than face. See
page 12 and on in this document.
http://tinyurl.com/k9v2rfw
A 28v battery at 1/2 capacity will not be as roubust
to the effects of cranking events.
Cessna went 100% 28v for manufacturing conveniences
and before the advent of the higher efficiency, geared
light weight starters.
It would be interesting to see those economics
re-evaluated but in the certified, heavy iron
business, it's not likely to happen.
The most compelling reason cited for 28v here on
the list was "my engine came fitted with 28v hardware
and I didn't what to change it out."
Posted: Sun Jul 28, 2013 3:06 am Post subject: 14V or 28V |
Bob
and all
Still didn't get any answer about the second part of my initial query.
How about keeping the 14V system and using a 14/28 voltage converter to feed
the radio?
Carlos
Posted: Sun Jul 28, 2013 4:16 am Post subject: 14V or 28V |
| Quote: | Still didn't get any answer about the second part of my initial query.
feed
the radio?
You could use something like this. Just make sure that you
size it to supply enough 24 volt power for your needs.
This will connect to your 12 volt system and supply 24 volts
to your radios.
http://aconinc.com/index.php?route=product/product&path=1_12400_12402&product_id=136
Using this would mean that there is no other mod required
to your aircraft electrical system thus maintaining a standard
12 volt system.
Roger
Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen
Posted: Sun Jul 28, 2013 4:29 am Post subject: 14V or 28V |
Carlos,
Check out this 14V to 28V converter at Aircraft Splice:
http://www.aircraftspruce.com/catalog/elpages/lsStepUpCon.php?clickkey=87526
Things you might want to consider are:
- Cost: $450 plus shipping
- Weight: 0.7 lbs, which is pretty low in my opinion, given it's TSO'ed
- Reliability: 100K hrs MTBF, not bad
- Output: 27.5V, 8 Amps or 220W, enough for your 16W transmitter power. The radio will probably pull 2.5 times that, so 40W isn't so bad and will be good for the converter's MTBF
- Heatsink: may require that you mount it to a metal surface, which is no problem in your RV
- Ripple: 25 mV P-P. This and the switching frequency may affect your radio's audio output and also ride on the transmission modulation. Depending on your install, your problem may be never or forever.
Seems like a lot of hassle for very little, but if you gotta have it, it may be the solution
Henador Titzoff
Sent: Sunday, July 28, 2013 7:05 AM
Subject: RE: AeroElectric-List: 14V or 28V
--> AeroElectric-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
Bob
and all
the radio?
Carlos
Posted: Sun Jul 28, 2013 6:08 am Post subject: 14V or 28V |
It will work, if you really want to do it. I've got a Garmin 430 28v
model on the shelf that I'll install in my RV-7 (12v system) with a
14-28v adapter. But the only reason to do that is that I got a 'deal' on
the radio. The adapter adds weight & costs efficiency. As I said in my
previous response, it's unlikely that you'll be able to tell the
difference in range between a 6 watt radio and a 16 watt radio.
Charlie
On 07/28/2013 06:05 AM, Carlos Trigo wrote:
Bob
and all
the radio?
Carlos
Eric M. Jones
Posted: Sun Jul 28, 2013 6:52 am Post subject: Re: 14V or 28V... or 42V? |
(from my Z-100 paper) Choosing a Voltage for Your Airplane Project.
Bob's Nuckolls (AeroElectric guru) often makes the point about the relative costs of using 14V automotive components, and I have to agree. If you went to buy your electrical system from the “28V-Store”, you'd find that most of the stuff was expensive, for certificated a/c (remember that they certify the milk, but they certificate the cow) and the selection would not be all that large. The “14V-Store” has all the bargains and selection to be sure.
In short, the advantages of 28V don't seem to warrant the added expense. Although 28V is very handy for producing the high currents needed to start big diesel truck engines, many get along fine on 14V. Super-capacitors are also finding use in starting diesels.
Is the auto industry going to 42V? (Arguments applicable to 28V too.)
I was spreading that rumor once. More recent rumors show advantages in staying at 14V; because LED lighting systems, microprocessors, and mosfets solid-state switches, are more efficient at lower voltages, while the use of single-wire power busses makes the argument about smaller wire gauges less important for small aircraft (higher voltages still do make sense for large aircraft). The integration of the starter and alternator works fine at 14V too.
The extinguishing of electrical-contact arcing is a difficult problem at 42V, and problems of load dump and transient voltages are much more severe. Higher voltage motors are smaller but they use smaller gauge windings too, thus the cost-per-watt of the motor goes up. A 42V system can injure or even kill mechanics and tinkerers. Trying to jump 14V and 42V vehicles can destroy the 14V vehicle’s electrical system.
Then too, 42V and 28V systems corrode faster than 14V systems. It’s a no-brainer that more volts is better from a motive-power standpoint, but many in the automotive field now say the move to 42V systems will never happen.
Big, really big aircraft use bunches of voltage buses, 12, 28, even 120VAC, and more to accomplish their various needs.
But for the small experimental a/c, Go with 14V. Use PerihelionDesign.com CCA to reduce the Fatwire weight.
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Sun Jul 28, 2013 8:12 am Post subject: 14V or 28V |
The B-52's I cut my avionics teeth on sported 400Hz,
208 3-phase systems for all but the lowest power
systems and those that HAD to run on batteries for
emergency situations.
Getting a 400Hz system to play well required constant
speed drives between the variable speed engine and the
alternator that really need to run at 12,000 or 6,000
RPM all the time. I think the B-52 had hydraulic
drives - a variable displacement pump plumbed to
a variable displacement motor. A governor modulated
the wobble plates such that for any RPM at the input
shaft, the output shaft speed was constant.
Nowadays, wild frequency systems are becoming more
prevalent. This is made practical by the advent of
high horsepower, brushless DC motors and a constellation
of high-voltage switching technologies to go with it.
The need for constant speed drives goes away.
Now the large system designer can carry much greater
flows of energy around the airplane on twisted trios.
The frequency of the ac no longer drives rotational
speed off the motors because the AC is rectified locally
to relatively smooth 270VDC with the same, acceptably
low ripple (5%) we enjoy from our 3-phase a 14v alternators.
The high voltage ac is easier to control in solid state
components with triacs so arcing issues associated with
mechanical contacts goes away.
The simple ideas are unchanged, the deck of cards has
be reshuffled to exploit technology advances in
high voltage semiconductors.
DC systems on large aircraft tend to be localized,
like the forward battery on the B787 is used for emergency
backup in the cockpit, the mid-ships battery primarily
used to crank an APU. In neither instance is the DC battery
power shipped very far on wires.
Local DC requirements are easily addressed with switchmode
power supplies not unlike those we find in our computers
and cell phone chargers. Pipe POWER around the airplane
on 115/208 VAC and convert it to DC locally as needed.
jluckey(at)pacbell.net Guest
Posted: Mon Jul 29, 2013 9:06 am Post subject: 14V or 28V |
You have to be careful when selecting power converters of this type.
Be aware of the power requirements. If the radio in question only draws 2 amps at transmit then that's 48 watts of power, P = IE (watts = amps x volts) that the converter must deliver when you key the mic. The one referenced is only 13 watts and would be inadequate.
Sent: Sunday, July 28, 2013 5:15 AM
--> AeroElectric-List message posted by: "R. curtis" <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)>
the radio?
to your radios.
12 volt system.
Roger
Posted: Mon Jul 29, 2013 9:23 am Post subject: 14V or 28V |
Jeff
Thanks for calling my attention.
In that case, I suppose the adequate should be this one
http://aconinc.com/index.php?route=product/product&path=1_12400_12406&product_id=436
or this one
http://aconinc.com/index.php?route=product/product&path=1_12800_12807&product_id=531
Is that so?
Carlos
De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Jeff Luckey
Enviada: 29 de julho de 2013 18:04
Para: aeroelectric-list(at)matronics.com
Assunto: Re: 14V or 28V
From: R. curtis <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)>
the radio?
to your radios.
12 volt system.
Roger
<br ========================
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234567
Eric M. Jones
Posted: Mon Jul 29, 2013 9:37 am Post subject: Re: 14V or 28V |
BTW: The presumption that a 28V radio has greater transmitting power than a 12V radio is, in principle, untrue.
113 Brentwood Drive
(508) 764-2072
Posted: Mon Jul 29, 2013 9:56 am Post subject: 14V or 28V |
Carlos,
You should start with the spec sheet of the radio that you want to use to determine its current draw. Then you can use the formula I provided to calc the required power. I would then select a power converter that gives you a significant safety margin of power; perhaps at least 20 percent greater power than your calculation indicates.
Let's hope someone on this List has done this before and can recommend a device that they have used successfully.
Sent: Monday, July 29, 2013 10:21 AM
Subject: RE: 14V or 28V
Jeff
or this one
Is that so?
Carlos
Subject: Re: AeroElectric-List: 14V or 28V
the radio?
to your radios.
12 volt system.
Roger
| 01234567
8
Posted: Mon Jul 29, 2013 10:08 am Post subject: 14V or 28V |
Eric
Would you please elaborate a little bit on your opinion?
But do it for an electron-idiot guy, please...
Carlos
-----Mensagem original-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Eric M.
Jones
Enviada: 29 de julho de 2013 18:38
--> <emjones(at)charter.net>
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=405583#405583
deej(at)deej.net Guest
Posted: Mon Jul 29, 2013 10:41 am Post subject: 14V or 28V |
| Quote: | Would you please elaborate a little bit on your opinion?
I'm not Eric, but I'll chime in. VHF radio transmissions are line of
site. For the most part, if you can see it, you can "hear" it via radio.
Several years ago I climbed to the top of a mountain which was about 1
mile ASL. A friend of mine was ~80 miles away in a direct line, on the
ground at maybe 200 ASL. We both had handheld radios, and were talking
to each other. He was using 1/2 of a watt, I was using 1/4 of a watt
(the lowest power setting of the radios). There was barely any
discernible difference between 5 watts (the maximum setting), and the
low power settings that we were using.
In general, for the typical distances that we are communicating in our
airplanes, combined with the height above ground, it just doesn't matter
if the radio is 8 watts or 16 watts. The signal is only going to go as
far as line of site under normal conditions (ie, no weird atmospheric
"skip" happening).
In other words, under typical circumstances, you are not going to be
transmitting any farther using 16 watts than you are at 8 watts.
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
tim2542(at)sbcglobal.net Guest
Posted: Mon Jul 29, 2013 12:15 pm Post subject: 14V or 28V |
Not arguing with that, but I believe the 430AW model is 28 volts only and is the one with the 16 watt transmitter.
Sent from my iPad
On Jul 29, 2013, at 11:37 AM, "Eric M. Jones" <emjones(at)charter.net> wrote:
