		jill(at)m-14p.com Guest
				 Posted: Sat Aug 10, 2013 6:03 am    Post subject: Long term engine storage feedback |
				Andy,
 We have had a lot of engines come through our shop that have been in
 longterm storage and here is what I have seen:
 1.  Richard is correct.  The cylinder walls are going to be the problem
 area.  If you rotate the prop shaft and look inside of the cylinder, you may
 see a patch of rust in the barrel.  Sometimes, it is surface rust but we
 have pulled suspect cylinders and found the corrosion to be deeper than what
 could be removed with a hone. This has been more the case with factory
 overhauled engines than new manufacture. (Caution:  If you rotate the prop
 shaft, you will disrupt the preservation process in the carb, air
 compressor, mags and cylinders.)
 2.  I advise my customers to replace the prop shaft seal on new, old stock
 engines that have been sitting for 7-8+ years.  This is recommended for
 convenience.  The last thing a new engine owner wants is a leaking prop
 shaft seal, so I automatically change this on the engines we sell. (The
 Russian rubber does not hold up well.) It is also inexpensive.
 3.  When we have the nosecase off, it is not uncommon to see some light
 corrosion on the cast magnesium case parts.
 Closely follow the depreservation process in the maintenance manual when you
 are ready to use the engine.  Your first oil change should be pretty quick
 after the first runs, as the preservative oil thickens with time.
 The dessicant in the spark plug holes is very good.  Years ago, an outfit in
 Kankakee advertised the 14mm plugs but I have never been able to get my
 hands on them.
 Pappy's oil consumption numbers are consistent with what we are seeing with
 our high compression pistons/rings. (We also provide stock compression.)
 Jill
 M-14P, Inc.
		kendal(at)acronut.com Guest
				 Posted: Sat Aug 10, 2013 6:13 am    Post subject: Long term engine storage feedback |
				Jill how should I preserve my engine that will be sitting for a few years.  I've sprayed inside the cylinders with LPS 3 but that's it so far.  Sounds like I should pour oil in them. What else can I do to preserve it?
 Kendal
 On Aug 10, 2013, at 10:00, "Jill Gernetzke" <jill(at)m-14p.com> wrote:
  Andy,
  hands on them.
  Jill
  M-14P, Inc.
		markdavis(at)wbsnet.org Guest
				 Posted: Sat Aug 10, 2013 7:50 am    Post subject: Long term engine storage feedback |
				Jill,
      Skygeek has them in stock.
 http://www.skygeek.com/dehydrator-plug-14mm-thread-ms3396-12.html
      Also, what is your opinion on fogging oil for preservation in lieu of
 pickling oil?  Or in combination with pickling oil where the oil doesn't
 contact the upper cavities of cylinders or the case?
 Mark Davis
 N44YK
		FatBoy
  Joined: 21 Oct 2012 Posts: 19 Location: Nashville, TN
				 Posted: Sun Aug 11, 2013 3:19 am    Post subject: Long term engine storage feedback |
				Thanks Gil  --  When I get to it (operative word: "when") I'll do the seal for sure.  I'd like to think the oil that was poured into the cylinders could fight off any rust, but again, I've never been down this road before.
 Thanks again for the feedback  --
 Andy
 On Aug 10, 2013, at 9:00 AM, Jill Gernetzke wrote:
  Andy,
  hands on them.
  Jill
  M-14P, Inc.
