pjeffers(at)talktalk.net Guest
Posted: Tue Aug 13, 2013 12:57 am Post subject: Coms port settings |
Hi,
I wonder if anyone can help. I have an out of date (but still very good) Lowrance 2000c GPS. The manufacturers have long since stopped supporting this device so I can get no help from them. I am trying to link this unit into a ‘Navaid AP-1 autopilot. Does anyone know how to set up the output port on my Lowrance GPS so that it will talk to the autopilot?
Pete
PS Simple question but is there a simple answer??
alanb(at)dpy01.co.uk Guest
Posted: Tue Aug 13, 2013 2:28 am Post subject: Coms port settings |
Pete, have you tried a google search for the manual?
Just tried Lowrance GPS 2000c Manual and came back with a few promising links to PDf docents that might provide the answer.
Alan
On 13 Aug 2013, at 09:57, " Peter Jeffers" <pjeffers(at)talktalk.net (pjeffers(at)talktalk.net)> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Hi,
Pete
cs.com
matronics.com/contribution
Posted: Tue Aug 13, 2013 3:15 am Post subject: Coms port settings |
Thanks Alan for that idea. Good idea but the manual refers you to Lowrance support for setups for different devices. Unfortunately Lowrance are just not interested and suggest you buy a Garmin??!! Such a shame because the 2000c is a great instrument. I guess they could not compete with the sheer mass of the Garmin organisation for aviation products.
Pete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Alan Burrill
Sent: 13 August 2013 11:28
Subject: Re: Coms port settings
Alan
| Quote: | <![endif]--> <![endif]-->
Hi,
Pete
| Quote: | | ===================================tp://www.matronics.com/Navigator?Europa-List===================================cs.com===================================matronics.com/contribution=================================== |
| 0123456789 | Quote: | | =================================== | 0 | Quote: | | =================================== | 1 | Quote: | | =================================== | 2 | Quote: | | =================================== | 3 | Quote: | | =================================== | 4 | Quote: | | =================================== | 5 | Quote: | | =================================== | 6 | Quote: | | =================================== | 7 | Quote: | | =================================== | 8 | Quote: | | =================================== | 9
Posted: Tue Aug 13, 2013 4:08 am Post subject: Coms port settings |
I have had some success getting workshop manuals etc for older stuff off ebay, people running the manuals
Through a photo copier and outputting it to a PDF file then selling the thing on CD for a few bucks
Worth a look, good luck
craig
[quote] [b]
Posted: Tue Aug 13, 2013 4:23 am Post subject: Coms port settings |
Hi Craig,
Thanks for that. I have got the original manual but all it says about the settings is that you need to set the send and receive ports according to Lowrance support. Lowrance support does not support the 2000c any more and have not do so for about three years hence they are useless as far as assistance is concerned.
I guess I need help from someone who set their system up a few years back.
Pete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of craig
Sent: 13 August 2013 13:08
Subject: RE: Coms port settings
craig
012345678901
rowlandcarson(at)gmail.co Guest
Posted: Tue Aug 13, 2013 4:35 am Post subject: Coms port settings |
On 13 Aug 2013, at 09:57, Peter Jeffers wrote:
| Quote: | I wonder if anyone can help. I have an out of date (but still very good) Lowrance 2000c GPS. The manufacturers have long since stopped supporting this device so I can get no help from them. I am trying to link this unit into a ‘Navaid AP-1 autopilot. Does anyone know how to set up the output port on my Lowrance GPS so that it will talk to the autopilot?
Pete - you might try posting your query on the Matronics Avionics list. The traffic is low (not many postings), but people there seem to display a wide range of knowledge in response to the most obscure queries.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
Posted: Wed Aug 14, 2013 1:26 pm Post subject: Coms port settings |
Peter,
The manual here: http://www.sportys.com/source/slashpages/manuals/2034.pdf
Appears to quite detailed on Page 82. The only ref to manufacturers is with ref to the wiring for the unit.
Is it the settings or the wiring?
Alan
On 13 Aug 2013, at 13:22, " Peter Jeffers" <pjeffers(at)talktalk.net (pjeffers(at)talktalk.net)> wrote:
Hi Craig,
Pete
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of craig
craig
01234
5
Posted: Thu Aug 15, 2013 3:12 am Post subject: Coms port settings |
Hi Alan,
OK my problem is what boxes to tick on the Lowrance setup.
The first page gives a choice of NMEA output, NMEA input, or NMEA GPS input. I presume I should tick the first one ie NMEA output.
Once you make this choice then you have to CONFIGURE NMEA, this gives me the option of choosing one or more of the following:- GLL, RMC & RMB, GGA, GSA & GSV, or APB.
All this leaves me stone cold as I have no idea what any of these options mean or refer to. Have you any thoughts on any of that?
Hopefully
Pete
Sent: 14 August 2013 22:26
Peter,
Alan
Hi Craig,
Pete
craig
| Quote: | | [b]http://www.matronics.com/Navigator?Europa-List[b]http://forums.matronics.com | 0
Posted: Thu Aug 15, 2013 3:35 am Post subject: Coms port settings |
Ah now I get it.
NEMA output and then RMC & RMB.
Based on what's used on my Trutak set up.
Speed is 4800
Probable best if you ring or let me know when you next at WAP and I can help.
Alan
On 15 Aug 2013, at 12:11, " Peter Jeffers" <pjeffers(at)talktalk.net> wrote:
[quote] Hi Alan,
Hopefully
Pete
Peter,
Alan
On 13 Aug 2013, at 13:22, " Peter Jeffers" <pjeffers(at)talktalk.net> wrote:
> Hi Craig,
Posted: Thu Aug 15, 2013 5:37 am Post subject: Coms port settings |
Ha Alan,
Are you going to Laddingford this weekend?
Pete
Sent: 15 August 2013 12:35
Ah now I get it.
Speed is 4800
Alan
On 15 Aug 2013, at 12:11, " Peter Jeffers" <pjeffers(at)talktalk.net (pjeffers(at)talktalk.net)> wrote:
<![endif]--> <![endif]-->Hi Alan,
Hopefully
Pete
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Alan Burrill
Peter,
Alan
Hi Craig,
Pete
craig
| 123
