Needing 912 parts
gregsmi
PostPosted: Thu Aug 22, 2013 4:44 am    Post subject: Needing 912 parts Reply with quote
Guys, I am working on a Pulsar and have a 80HP 912 engine that is missing a few parts. I will order from Lockwood if we cannot find here.
Crossover equalizer tube for carbs
Fuel pump
Banjo oil fitting
Vacuum pump
Voltage regulator
Air cleaners
Also, got a question, do you use a gasket on the Aerodesigns exhaust system where the expanded pipe enters the head port?
Thanks, see you next week in Lawrence.
Greg
briana(at)xtra.co.nz
PostPosted: Thu Aug 22, 2013 1:03 pm    Post subject: Needing 912 parts Reply with quote
Hi Greg,
Re the exhaust fitting - - - the system ought to use the Rotax nipples, welded to the exhaust system, at the head entry points. The exhaust ports on the heads have a countersunk area that mates with the crox flange on the nipples. It is tightened in place with the solid flange, and no gasket is used.
Beware - - - the Aerodesignes exhaust system will very likely crack near the rear two cylinders !
Brian
On 23/08/2013, at 12:41 AM, GREGSMI(at)aol.com (GREGSMI(at)aol.com) wrote:
[quote] Guys, I am working on a Pulsar and have a 80HP 912 engine that is missing a few parts. I will order from Lockwood if we cannot find here.
Fuel pump
Banjo oil fitting
Vacuum pump
Voltage regulator
Air cleaners
Greg
esalehto(at)yahoo.com
PostPosted: Thu Aug 22, 2013 1:34 pm    Post subject: Needing 912 parts Reply with quote
Hi,
What has happen to Rick's design and Rick? Just curious to know? Have not heard anything from him a while.
Esa
Pulsar XP
Rotax 911
Sent: ‎8/‎22/‎2013 4:12 PM
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Re: Needing 912 parts
Hi Greg,
Brian
Fuel pump
Banjo oil fitting
Vacuum pump
Voltage regulator
Air cleaners
Greg
st"'>http://www.matronics.com/Navigator?Pulsar-List
matronics.com
://www.matronics.com/contribution
w7ikt(at)fly-web.us
PostPosted: Thu Aug 22, 2013 1:49 pm    Post subject: Needing 912 parts Reply with quote
Greg,
I have a fuel pump. Bought it back in 2006 when Bob Hartunian put a group purchase together.
Still packed as delivered.
Think rotax came out with a new fuel pump 2010 or 2011.
Let me know if you are interested.
Still have a few other Pulsar parts:
Wheel pants (large wheels)
tool to pull wing pins.
God Bless
Bob (W7IKT) Carol (N5CBQ) Heiser
Fuel pump
Banjo oil fitting
Vacuum pump
Voltage regulator
Air cleaners
Greg
Checked by AVG - www.avg.com
08/21/13 [b]
ccoulter(at)wavecable.com
PostPosted: Thu Aug 22, 2013 3:39 pm    Post subject: Needing 912 parts Reply with quote
Greg
Crossover equalizer tube. Use rubber tubing.
I have a new fuel pump.
Clarke
On Thu, 22 Aug 2013 08:41:49 -0400 (EDT)
here.
Fuel pump
Banjo oil fitting
Vacuum pump
Voltage regulator
Air cleaners
Greg
