RV8-List Digest: 0 Msgs - 08/30/13
dennisfox(at)persona.ca
PostPosted: Sat Aug 31, 2013 5:22 pm    Post subject: RV8-List Digest: 0 Msgs - 08/30/13 Reply with quote
My RV8a project is ready for wheels, and I keep thinking about the brake
system and lines. Seem to me like some weight could be saved by going with
3/16 brake lines, (smaller line and less fluid). Problem with small lines
is the heavy viscosity of A/C hydraulic oil, especially when cold.
Solution would be automotive Dot 3 or Dot 4, but are there compatability
issues with the Matco master cylinders and Cleveland calipers? Maybe new
o-rings could solve the problem? Anyone know the answer?
gengrumpy
PostPosted: Sun Sep 01, 2013 3:37 pm    Post subject: RV8-List Digest: 0 Msgs - 08/30/13 Reply with quote
I have been using quality ATF in my RV10 for 7 years now with no problems.
Flash point is about half way between the old 5606 hydraulic fluid and the new stuff, but significantly cheaper and easier to get.
grumpy
On Aug 31, 2013, at 8:22 PM, Dennis Fox <dennisfox(at)persona.ca> wrote:
My RV8a project is ready for wheels, and I keep thinking about the brake system and lines. Seem to me like some weight could be saved by going with 3/16 brake lines, (smaller line and less fluid). Problem with small lines is the heavy viscosity of A/C hydraulic oil, especially when cold. Solution would be automotive Dot 3 or Dot 4, but are there compatability issues with the Matco master cylinders and Cleveland calipers? Maybe new o-rings could solve the problem? Anyone know the answer?
