		Fred Klein
				 Posted: Tue Sep 03, 2013 11:04 am    Post subject: solid state contactors |
				I'm wondering if anyone has installed or has the expertise to evaluate these:
 	http://www.periheliondesign.com/powerlinkjr/PowerLinkJrIIIManual.pdf
 thanks for any insights,
 Fred
				 Posted: Thu Sep 05, 2013 12:04 pm    Post subject: solid state contactors |
				On 09/03/2013 09:03 PM, Fred Klein wrote:
 Yeah, I have seen them too. For some purposes they could be fine.
 However I just use regular switches for almost all low power purposes.
 In the case I need relays (like for high current devices) I like to use
 real relays instead of SSR's. Look at the heat sink these SSR's have.
 They are there for a reason. The reason is voltage loss (and subsequent
 heat production in the relay). And one of the reasons you use a relay
 instead of a switch is to eliminate voltage loss due to lenghty wires.
 So these SSR's negate their own purpose in some way.
 I use regular car relays for high current switching purposes. Our
 aircraft see much daily less use than cars, and if these relays are fine
 for daily use in a car, they should be fine for an aircraft as well.
 Frans
		paul.the.aviator(at)gmail Guest
