Richard Lamprey
Posted: Sat Aug 31, 2013 7:53 am Post subject: Classic radiator(s) needed |
Greetings from Kenya
Does anyone have a spare starboard classic radiator? I could buy the pair if you are selling as a pair. I have a UK address to send to if necessary.
My starboard radiator has sprung a small leak. Has anyone tried Radweld or something similar?
Best,
Richard
Classic reg 5Y-LRY
paul.the.aviator(at)gmail Guest
Posted: Sat Aug 31, 2013 8:13 am Post subject: Classic radiator(s) needed |
Hi,
I took my XS radiator to a repair shop and they aluminum brazed & pressure tested it for $50.00. Another, less appealing alternative is that when I was researching this I found several examples of JB weld (Black) successfully being used.
Paul
pjlevi(at)gmail.com Guest
Posted: Sun Sep 01, 2013 2:30 am Post subject: Classic radiator(s) needed |
Richard
I appreciate you are in Kenya, however the following may help.
I recently had to have my radiator repaired at an annual check. Europa were unable to provide a replacement at the time. My engineer, Gary Johnson, found somewhere in the UK some engineers, I believe they were a motorcycle repair organisation, and they refurbished the radiator and it came back as new at extremely modest cost, far less than replacement. May I suggest you contact Gary - his e-mail address is <thehighflyer(at)aol.com (thehighflyer(at)aol.com)> and you may be able to post your radiator to the people that repaired mine.
Alternatively you may be able to find similar motor-bike servicing specialists in Kenya as I understand that the Europa radiators were originally motorcycle radiators with minor modifications made in order to fit them to the aircraft.
Philip
Philip Levi
G-BWWB, Europa Monowheel Classic, Old Warden.
On 31 August 2013 16:53, Richard Lamprey <lamprey.richard(at)gmail.com (lamprey.richard(at)gmail.com)> wrote:
[quote] --> Europa-List message posted by: "Richard Lamprey" <lamprey.richard(at)gmail.com (lamprey.richard(at)gmail.com)>
Best,
Richard
Classic reg 5Y-LRY
http://forums.matronics.com/viewtopic.php?p=407814#407814
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
Richard Lamprey
Posted: Wed Sep 04, 2013 7:27 am Post subject: Re: Classic radiator(s) needed |
Thanks very much Philip and Paul, and also to Kevin Burns who has been in touch by email.
So, thanks, good leads to follow:
Best
Richard
Kenya
