601XL B 3300 carb / left - right bank temp differential
mhubel
PostPosted: Thu Sep 26, 2013 6:23 am    Post subject: 601XL B 3300 carb / left - right bank temp differential Reply with quote
Rich,
I has a similar configuration when I had a Jabiru, finally switched
to the Rotac carb but I think one observation may still be significant.
I found that having the airflow come from the top instead of from one
side significantly helped with the Rotec and I expect it would with the
Bing. I believe this was because the airflow even with straighteners or
a "Cobra" is still unsymmetrical and with airflow from the top it is
more symmetric - at least from side to side.
Unfourtunately, the airbox as supplied by Jabiru does not make
such air routing easy, it would need to be modified. Something to
consider. You can see www.n708hu.com 1066 and 1069. More hose than I
would have liked but it did work.
On 09/26/2013 9:58 AM, Rich wrote:
For the record I am building a 601XL (B) with the Jabiru 3300!
Over the past years of building my plane and reading the Matronics list for the Jabiru 3300 Engine and the Zenith list there has been a lot of conversation on Left/Right Bank Temp differential due to the sharp bend of the intake hose joining the Air box to Carb. I have read on the forums simply twisting the Carb a bit in its couplings and this improves the condition. Others may also add veins in the intake tube to straighten out the airflow a bit. For a While, the Cobra tube was offered but that source has moved on to other things in life so they say.
My thoughts are to rotate the tube on the Carb 90 degrees and then plumb my way back to the air box and also moving the coupling on the air box.
So with my above statements, what is the better way to attack this problem before my targeted first flight next spring since I am still in the wiring and final installation mode?
I know this will draw many opinions but I consider learning from what others did and listening to wise old owls is probably a good thing!
Thanks for sharing your opinion and what you did yourself.
Rich Simmons
Murfreesboro, TN
- Rich
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com
