spcialeffects
Posted: Wed Oct 23, 2013 7:28 pm Post subject: Classic Manuel |
I am just about to bond the 1/2" bushes to the cockpit module along with the spar end caps but have a question. The original method was to set the cockpit module upside down and then rig everything but now they get you to stand it up on end to rig it all why? Also I would prefer to rig it all the 1st way because I can support the wings much safer and better this way, so could someone please send me the original pages of the Manuel to refer to. Thanks Frank
asarangan(at)gmail.com Guest
Posted: Wed Oct 23, 2013 9:49 pm Post subject: Classic Manuel |
I can't see why setting the wings upside down will be easier, but it
might have been different with the classic wings. I think the vertical
setup will take less floor space, as you can stick the wing tips out
through a small door or even window. With the module set vertical, it
is very stable because the front firewall tunnel is sturdy and flat. I
built a wing dolly to clamp the wings in the vertical position and
roll it around into position. If you are interested, you can see my
setup at this site:
http://www.sarangan.org/aviation/europa/index.html
On Wed, Oct 23, 2013 at 11:28 PM, spcialeffects <spcialeffects(at)aol.com> wrote:
http://forums.matronics.com/viewtopic.php?p=411280#411280
Fred Klein
Posted: Wed Oct 23, 2013 10:09 pm Post subject: Classic Manuel |
On Oct 23, 2013, at 10:48 PM, Andrew Sarangan wrote:
Andrew...great site...
Is there a way to scroll thru your photos?...or must one click back to the small images every time in order to move forward?
Fred
pete(at)lawless.info Guest
Posted: Thu Oct 24, 2013 1:15 am Post subject: Classic Manuel |
Hi Frank
My build number was 109 and it was the vertical method when I did mine in
the mid 90's. Any upside down installations must have been very early on.
Pete
Posted: Thu Oct 24, 2013 7:47 am Post subject: Classic Manuel |
Fred
Thanks for your input. Unfortunately one has to back out to the
thumbnails in order to get to another photo. I suppose I could put
links in each frame to advance to the next, but I wanted to keep the
overhead of each frame low so the response is fast.
On Thu, Oct 24, 2013 at 2:08 AM, Fred Klein <fklein(at)orcasonline.com> wrote:
setup at this site:
Fred
