Low RPM @ full throttle
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
jpkarnes
PostPosted: Wed Oct 02, 2013 1:03 am    Post subject: Low RPM @ full throttle Reply with quote
Hi all,
After installing my Ram heads and dual dizzy's, I am only getting 3600 RPM (at) full throttle. The engine is running smooth with no hiccups, just only getting 3600 RPM. The Bing carbs are the original setup with the old heads and Subaru ignition. Any suggestions?
John K.
Zenith 601 HDS
Bremerton, WA
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
larrycmcfarland(at)gmail.
PostPosted: Wed Oct 02, 2013 5:52 am    Post subject: Low RPM @ full throttle Reply with quote
Hi John,
I’d look at the butterfly travel and linkage at the carbs.  If you’re running distributors, I’d look at fly-weights in the distributor.  Check your carbs and jets for corruption from the tank. I was surprised to have lots of aluminum swarf and grit from construction of my tanks with same result.  Smooth could be with misadjusted valve gap and or timing.  Get a good filter on your fuel line ahead of the carbs. I used a see thru type, no problems.
Larry McFarland
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of jpkarnes(at)comcast.net
Sent: Wednesday, October 02, 2013 4:04 AM
To: stratus-list(at)matronics.com
Subject: Low RPM (at) full throttle
Hi all,
John K.
Zenith 601 HDS
Bremerton, WA
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
